Question about Boating
Tohatsu M40C outboard misfire when advancing throttle slowly, seems OK when throttle moved to max RPM quickly. Have replaced CD unit to no avail. suggestions please.
Original fault appeared to be carby, but guy says float set to correct height now, I still think carby float level too high? As I said CD unit has been replaced and coil has been checked.
2 Suggested Answers
SOURCE: i need a free workshop manual for tohatsu outboard
how can i get service manual for a tohatus m40c 1992?
Posted on Apr 14, 2011
Tohatsu 30hp M30 outboard.
Sound like problem with ignition or fuel delivery system
Feb 22, 2018 | Boating
Misfire on Tohatsu outbaord.
one would assume so but as you have not mention if it is a 2 stroke or 4 stroke , that assumption would possibly be wrong
2 strokes use reed valves between the carby and manifold and the crankcase and in outboards these reed valves can split and not function properly especially at higher prms
these reed valves allow fuel mixture in when the piston goes up and shut off when the piston comes down creating a pressure in the crankcase which pushes the mixture up the bypass of the cylinder into the combustion chamber
if these reed valves are not working properly or the crankshaft seal are failed this compression in the sump doesn't occur properly and engine running problems result
IF it is a 4 stroke the soaking the carby in cleaning fluid will only remove 1/2 the problems
It is best to have the carby fully overhauled by an accredited outboard mechanic as there will still be corrosion in the body and mixture passages that cleaning fluid alone will not remove.
have the ignition system checked as it may be an overheating component ( coil --ignition module) that is causing the failure.
Aug 11, 2015 | Boating
What year is Tohatsu M15B2 serial number 351A33838 outboard
Hi!
You can contact Tohatsu directly using the form provided at the link below.
Hope this helps,
-Steve
http://www.tohatsu.com/contact/wiz_modelyear.html
Aug 06, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Gear slippage at 10 mph
Sometimes cause by TPS sensor[RPM]
May 10, 2013 | Cars & Trucks
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
My 1996 130 Johnson outboard is difficult to keep running when it starts. Doesn't seem to be priming correctly. Once I manage to get it into gear and moving w/o stalling, it runs great. Just having...
check your idle stabiliser-it advances /retards the ignition timing directly associated with RPM-if you dont notice any differencewhen moving the spaRK advance lever then replace it-no seviceable on mercs anyway!
Aug 22, 2009 | Boating
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Apr 12, 2009 | Boating
'93 940 no turbo engine stuck at max RPM
YOU IDLE CONTROL VALVE IS GOING BAD ON YOU. TRY TO CLEAN IT BUT BEST TO JUST REPLACE. LOCATED UNDER INTAKE MANIFOLD
Dec 23, 2008 | 1993 Volvo 940
Boating Logo
56 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
