Question about Husqvarna Garden
I have a mcculloch 260 cls bought it towards the end of september 2013 i forgot to remove petrol ready for storage (never had a petrol trimmer before) and now it just idles then cuts out after a few seconds of throttle can some one please help?
  • 5 Answers
SOURCE: mcculloch petrol trimmer
Hi
Please try these suggestions if youve not done so already:
  1. Clean the air filter
  2. Check fuel primmer bubble (if it has one pressurizes)
  3. Spark at plug, when pulling cord (When they degrade, some plugs can fire itermittently - check also with a continuity meter) BUY a new plug
  4. Fuel in present in the combustion chamber (use a torch to see inside plug hole if the if the piston head looks wet from petrol) also the smell will definately be strong
  5. You ay need to adjust the carb idling screw to increase idling speed when engine has warmed up.
These things I tried after investigation & worked for me, unit starts up a treat. Hope thisa helps
Aky1967
Posted on Feb 04, 2009
  • 4 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
did you try fresh gas
Posted on May 31, 2009
SOURCE: Stihl FS45 2 cycle string trimmer. Bought in 5/06
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Posted on Jun 24, 2009
moretons
  • 155 Answers
SOURCE: mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Posted on Jul 25, 2009
  • 71 Answers
SOURCE: Trimmer dies when you apply throttle
Sounds like it might be getting to much gas. What position is the choke in during all of this? If you're giving it throttle it may be flooding itself out.
Posted on Aug 27, 2009
Where do the three petrol pipes connect
http://www.mcculloch.com/ddoc/MCCI/MCCI2002_AAaa/MCCI2002_AAaa_Virginia-MH542_.pdf
Oct 01, 2014 | Garden
Oil for Mc Culloch M T 325 Cls, weed trimmer
Hi and welcome to FixYa, I am Kelly. I looked up your manual here:
http://www.mccullochpower.com/node7877.aspx and entered MT325CLS as the model number No such number. There is a different model number / product code that may start with 957 on the data plate / label.
I also checked Australia and UK without any success.
http://www.mcculloch.biz/uk/support/owners-manuals/?query=Trimmer&types=O
http://www.mcculloch.biz/au/support/owners-manuals/?query=Brush+cutter&types=O
I tried trimmers and brush cutters for both regions and the US McCulloch site. If you have a better model number (Product code) I will look again.
Kelly
Sep 24, 2011 | Garden
What is the petrol to oil ratio for a mccullogh tivoli 65 hedge trimmer
40 to 1 will do, i run mine on 30 to 1 i look at it this way,,if it smokes a little there is oil getting to the big ends and the engine lasts longer
Jul 16, 2010 | McCulloch Trimmer Plus Attachment: Add On...
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
My mcculloch petrol hedgetrimmer wont start, the pull cord has a lot of resistance. I have changed the spark plug and cleaned the air filter but still no joy.Interestingly When i remove the spark plug i...
The fact that your engine turns over easily with the spark plug removed simply means that, with the plug removed, there is no compression, so the piston goes up and down very easily.
If it has been a while since you ran the machine, and if you left gas in it, your carb may have gotten gummed up from the gas losing it viability and turning to something like varnish. You might try spraying carb cleaner into the carb (with the air filter removed), let it sit for a few minutes, then try starting. In the future, you probably should get some fuel stablizer (available at almost any hardware store) and add it to the fuel that you use for your small machines. It will keep the gas viable for a much longer period of time.
Hope that you are lucky enough that the carb cleaner, a good dose, will work. If not, you may have to disassemble and clean out your carb. (if you've never done that, a series of digital camera photos so you know where to put things back is a good idea).
Oct 18, 2009 | McCulloch Garden
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
64 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
