GE 24 in. GSD2220Z Built-in Dishwasher
Problem for GE 24 in. GSD2220Z Built-in Dishwasher
I have a GE GSD2230Z00WW dishwasher water will not
By jkgerard on Jun 18, 2009
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Solution #1
posted on Jun 19, 2009
Not Rated)
localwonder
Rank: Guru  GE Expert
Rating: 92%, 2879 votes
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Comments:
Jun 19, 2009
- In most cases, this will be the direct result of a faulty inlet water valve assembly.
Was this helpful?
Yes
No
Popular Solutions for GE 24 in. GSD2220Z Built-in
Questions and Unsolved Problems for GE 24 in. GSD2220Z Built-in
Do you recommend GE 24 in. GSD2220Z Built-in Dishwasher?
Answer
Answer
hi.. i just install dishwasher...i turned the valve on and water started coming out of the side into... (More)
Answer
ge gsd2000, random problem of no water coming in. sometimes it runs dry and if stopped and and... (More)
Answer
panel does not illuminate circuit breaker OK no power to unit?
Answer
I have a GE dishwasher and am getting a C4 code.
Answer
I have a GM 975-110 dishwasher and can't work out how to do a short wash program on it as I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
