Question about Samsung Televison & Video
My Samsung 3D TV continually changes antenna input, what causes that to happen?
3 Suggested Answers
markfreedman
  • 312 Answers
SOURCE: will shut off completely even
Hi, This sounds very interesting.
Here is what I would do.
1 I would, if you haven't done this already, connect the samsung into a different input. If you have a Video Input for a Laser Disk Player or VCR use the composite (yellow) from the DVD and analog left and right through the same. See what happens.
Additionally if your receiver has a "phono" input DO NOT USE THAT. It is super sensitive. Phono requires around 5/1000th of a volt for full output. Where as the CD, Aux, VCR and others require 1 volt for full output. An input overload condition will occur. That can shut down the receiver.
If you are having your receiver shut down with the samsung TV attached to a high level input, then the fault is definitely with the TV. It is defective. In this case contact samsung.
Here's the link
http://www.samsung.com/us/support/
Hope this helps.
Best Regards,
Mark
Posted on Jan 04, 2011
Terry Corrow
  • 10875 Answers
SOURCE: I lost my antenna input when moving tv and gained an unwanted pc input.
hook up antena,does it really create a problem to have pc show up when you dont use it?
Posted on Jul 04, 2015
Samsung Tv #un46c8000xf changes video sources.
The mother board is faulty. You have to change the main board. If you wiah to get some details about flat panel TV repair then check the below link.
http://electro-medical.blogspot.com/
Jul 06, 2016 | Samsung Televison & Video
What is causing solarization?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 30, 2015 | Sony KDL-55HX800 55" 1080p 3D Ready LCD TV...
Source changes by itself when watching tv.
Check your buttons on the TV . Sounds like input or source button ( which ever one they call it ) is pushed in & stuck . Only way to make sure would be to disconnect it & see if it still changes inputs .
Jan 12, 2015 | Samsung 46 UN46C7000 3D TV
Input changes without using remote control
Check input button on tv itself . Might be stuck .
Jan 12, 2015 | Samsung UN46C7000 46" 3D LED TV 1920x1080,...
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Samsung un55c8000 no signal from any inputs
Contact the authorized service center for Samsung. HDMI input software should be updated. Gopakumar Gopalan Google
May 27, 2014 | Samsung UN55C8000 55 in 3D HDTVReady LCD...
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
I bought a new Samsung LED 40" Series 5 TV. However, after connecting to the tv cable line, i get message " weak or no signal" and not able to get any tv signals. What could be the problem?
You usually hear "weak or no signal" when the tv's input is set to air. Check to see if changing the input might help. Or if you are using an antenna to get your tv, then maybe your antenna is not powerful enough. The new digital signal is weaker than the analog, so antennas that once worked might not work as well now. Hope this helps!
Apr 06, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Will shut off completely even bypassing standby mode after about 10 minutes of tv input with the new samsung 3d led tv. this does not happen with other equipment such as the cd player. all cables are...
Here's the link
Hope this helps.
Best Regards,
Mark
Jan 04, 2011 | Harman Kardon AVR 55 Receiver
Televison & Video Logo
14 people viewed this question
Henry  Thomas
Henry Thomas
