Question about Silver Floss Chopped Sauerkraut
Sauerkraut Not fermenting can I open jars and add more salt . Have picklemeister set up?
I need a list of acidic foods and a list of alkaline foods
Hi Samuel,
Here is a free printable food chart of acidic and alkaline foods courtesy of Greenopedia.com http://greenopedia.com/wp-content/uploads/Alkaline-Acid-Food-Chart-Printable.pdf
Please keep in mind:
Some foods can be listed on the acidic or alkaline side depending on the source. Some of these food items are tomatoes, soy products, nuts & seeds, or fermented items such as sauerkraut.
Not all foods are what they seem either. Citrus would obviously be on the acidic side, right? Not true! Limes, oranges, and grapefruit are actually alkaline forming fruits!
Artificial sweeteners, alcohol, and highly processed foods are highly acidic forming that offer little or no nutritional value. These foods should be avoided or eaten very sparsely.
Not all acidic foods are unhealthy and often offer other nutritional benefits so make sure you don't avoid everything acidic and maintain a balanced diet.
Oct 30, 2016 | Pool & Spa
Tip
Play touch jar files games on samsung corby in full screen
download any touch game in jar of resolution 240x320 and add it to winrar & open it in winrar then open the folder META-INF then open MANIFEST.MF in notepad then add a line MIDlet-Touch-Support: True
on Jul 30, 2010 | Cell Phones
Can I can cooked sauerkraut and pork
It depends on how you wish to cook it and the type of sauerkraut being used. Types with sugars shouldn't be cooked. It is best used as a marinate instead of direct cooking as the wilted cabbage will smoke/burn faster than the pork will cook. If its to be stuffed into the chops, that is possible but it depends on the thickness of the chops and any exposed sauerkraut.
Aug 29, 2015 | Grilling
How do I add salt
  • 99.9% pure salt only
  • Open the bag
  • Pour and distribute salt evenly throughout the pool
Feb 19, 2015 | Pool & Spa
How do I mess around with the alcohol content of my homebrewed beer? The last few batches have just not been alcoholic enough.
If you want to increase the alcohol content to your beer, you need to add more fermentable sugar to the yeast. Fermentable sugars include; malt, honey, molasses and corn syrup).
This will increase the alcohol but you shouldn't go crazy as there is a limit to what you can add before you mess it up.
Feb 21, 2013 | Crafts & Hobbies
I Have a Easy Set Pool 15X36, And a Salt Water Generator How much Salt do I add for the first Time?
The Compupool CPSC/CPA Series is recommended to run at a salt concentration of 3500 ppm. If you are not installing a Compupool unit, check your manufacturer's instructions for their recommended level of concentration . Use a salt that is at least 99.8% pure NaCl. The preferred salt is an evaporated, granulated, food quality, NON-iodized salt. Avoid using salt with anti-caking agents like sodium ferrocyanide, also known as yellow YPS (prussiate of soda. These cause some discoloration of fittings and pool surface finishes. DO NOT use calcium chloride.
Using a salt water test strip, measure the current salt level of your pool. For the Compupool generators, ideal is 3500 ppm. If the level is low, determine the number of gallons in your pool and add salt according to the Salt Table. For example, if your pool has 15,000 gals of water and your current salt level is 2500, you need to add 125 lbs of salt.
Jun 08, 2011 | Sport & Outdoor - Others
Dishwasher has a terrible odor in it. I'm guessing it came from an empty sauerkraut glass jar and lid I put through the wash, heated dry and sanitize cycle. How do I get rid of that nasty, something...
Check whether the smell comes from the main drain. Pull your dish washer drain hose and check.
Leave dishwasher door open for few hours. Hope no rate has died inside the machine.
Run a empty wash several times!
Sep 26, 2010 | Whirlpool Dishwashers
Lost manual
At initial startup add 290 pounds of salt. Add 75 pounds if low salt warning appears. Set the timer to run the pump for 10 hours per day.Get a downladable owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
Bread is dense and lopsided. The right end (from the right kneading blade) is "normal" but the left side is half the size. Both kneading blades do spin during the kneading process, but the same result with...
Hi Dan B,
Sorry about your bread problems. It is depressing to me to find an unsatisfactory result after going through the whole baking rigamarole. I had a similar problem early on, but I live in the Denver area, so I was also dealing with the high altitude problems, too. I started using Vital Wheat Gluten in all my bread recipes, and it helped a lot. I use a tablespoon per cup of flour, but you may want to start with a half tablespoon. I also put the salt in with the liquid ingredients, because you're not supposed to let salt touch the yeast. I also make sure to use non-iodized salt, because the iodizing stuff does bad things to the yeast. The final thing I always do is to set the timer for 10 minutes after it starts the knead cycle, and then I open the lid and touch the dough to see if it is too wet (add flour by tablespoons) or too dry (add water by tablespoons), until it feels and looks right to me. You are probably already doing most of these things already, but I thought I'd mention them just in case. Anyway, hope one of these things helps. Happy Baking!
Mar 25, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Silver Floss Chopped Sauerkraut Logo
Top Silver Floss Cooking Experts
Tom Chichester
ray gallant
Are you a Silver Floss Cooking Expert? Answer questions, earn points and help others
