Question about Cameras
List of dvd's available for rent - Cameras
How do I rent a movie on nexflex?
You do not rent movies on NetFlix. You signup for an account which allows you to watch any movies they have available. You need to have a device such as smart TV, DVD or computer attached to your TV supports NetFlix.
Jan 03, 2015 | Sony Original Tv Vcr Remote Control Rm-841...
I signed up for Netflix streaming. When I pick a movie it shows that I have to RENT it for about $4.00. I thought there was a flat rate per month. This could get a little pricey this way. If I watched...
Netflix has 2 separate services: Streaming and renting. The movie you're looking at is only available to rent, which you can get unlimited for $7.99 per month. You will however need to wait for it to be mailed to you, but there are no late fees.
More information can be found here:
https://dvd.netflix.com/
Aug 25, 2014 | Computers & Internet
Samsung dvd player does not read dvd disc.it reads "no disc".
I also have a Samsung Dvd player. If it is a dvd you burned yourself it may not recognize the disc. If you have loaded a purchased or rented disc and it still won't load, I would say the head is dirty or the unit is defective. I would try a head cleaner first.available at most electronics stores If that doesn't work you probably will need to send it in for repair.
good luck
Apr 15, 2011 | Audio Players & Recorders
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
Apr 20, 2009 | Apple Power Mac G5 Desktop
Rented videos are freezing temporarily during playback
If the rented DVD is too scratched it will cause the DVD player to pause while it tries and find the next available playable area on the disc. This may cause the player to skip to another part of the movie. Try wiping the disc with a damp cloth from the centre towards the outer rim and dry the same way. Fingerprints ect. also cause problems. If the scratches are circular the player will have a hard time trying to play the disc. If the scratches are straight and small it shouldn't cause too much problems.
Mar 17, 2009 | Sharp DV-SR45U DVD Recorder
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
Zone Free Code for Panasonic DMR E85H
A special remote is used to change the region code. However, to my knowing, it is not availble for the normal consumer.
Mar 25, 2008 | Panasonic DMR-EH50 DVD Recorder
DVR-510H
Not sure which code you mean. If you are talking about the region code, you need to use the service remote, which is available only to dealers. However, you can do a search and find that there is a company in UK that will rent you a service remote for this purpose. Be prepared to pay up to $50 for this service.
see for example http://www.dvd-hacks.co.uk/mods/piondisc.htm
Good luck
Dec 27, 2007 | Pioneer DVR-5100H DVD Recorder
Wont play some newer rented DVD movies
If it is a blue ray, you need a blue ray dvd player.
Aug 26, 2007 | Curtis CMD5000 DVD Player
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
