Question about Avanti Kitchen Ranges
Matag gas stove model mgr4411bdw igniters won't work
SOURCE: Convert natural gas range to propane
I want
Posted on Jun 09, 2008
frcs68
  • 1605 Answers
SOURCE: Whirlpool gas range spark ignition problem.
check the burn head, there is a tube from the ignitor to the burner head. that is where the gas get ignition. now look at the burner head, there should have 2 small pin hole align with the tube. use a paper clip clean out the hole.
Posted on May 21, 2009
SOURCE: GE gas stove top igniters won t stop clicking
I got this problem yesterday. My 6-month old GE range/stove top was being cleaned by a cleaning lady and suddenly, the igniters started clicking nonstop. I had to shut down the circuit breakers. I googled the problem, and it seemed clear that the "spark switches" got moisture on them. The best site which described this is: http://www.appliance411.com/archive/25012_ge_gas_cooktop_not_working_.shtml
Some people said you could dry them with a blow dryer, and others said you need to replace these switches (which is not too expensive, but takes some time/skill). I was hoping against this, so I tried something along those lines: I removed all the parts of the stovetop - the grill, the "cap", the metal funky piece, etc. until there was nothing but the surface of the stove and holes going down to the igniter area. Then, I took an electric fan and kept it pointed at the stovetop all night long. After about 10 hours, I turned the circuit breaker back on. No more clicking! And the burners all work! So, I think I essentially did the "hair dryer" solution, but did it more longterm without having to watch the clock to see if I did it long enough. Anyway, I don't normally post these things, but this discovery really helped me and I hope it helps someone else!
Posted on Jul 09, 2009
SOURCE: Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Posted on Aug 31, 2009
  • 3640 Answers
SOURCE: Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Posted on Jan 31, 2010
Testimonial: "Thank you!! "
Igniter glows but why doesn't burner light?
Igniter could still be faulty(not hot enough) or burner control valve
faulty. press the helpful button and check link videos below
Gas Stove Top Burners Not Lighting Not Working
Gas Stove Ignitor and Burner Not Lighting
Daddy Chores Gas range won ignite How to fix it
Jan 22, 2016 | Kitchen Ranges
Stove burners won't light
sounds like the igniter is faulty try a local h/ware or plumbing shop for a new piezo ignition
Feb 02, 2013 | Hotpoint RGA524 Gas Kitchen Range
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
Gas oven won't turn on, stove top works fine.
check if the igniter is getting a 110 volt power if yes replace the igniter
Sep 05, 2011 | Kitchen Ranges
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Installed a matag gas stove model # CRG9700BAL. burners work but push button to turn oven on and an error comes up F3. How do we fix this
F3 is a sensor error. The sensor is in the oven it is a metal rod coming in on the back wall of the oven, it is a little smaller than a pencil. It is either gone bad or came unplugged. It runs up the back to the electronic clock, there should be two wires on it and 2 connections to check.
If you take the back off the stove be sure to unplug the power cord first.
May 07, 2010 | Maytag MGR5751AD Gas Kitchen Range
Kitchen Ranges Logo
16 people viewed this question
Top Avanti Kitchen Ranges Experts
Shawn DuRee
ray gallant
Tom Chichester
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
