Question about Vehicle Parts & Accessories
The car wont start and it wont turn on due to the problem which is something in the car that is draining the battery till its completely flat and then it wont start even though the alternator is stil
The main male battery fuse was blown and i made a breach to the fuse cause i was in the middle of nowhere the the problem started of the car's ignition not responding.
    Habit-Forming:
  • 62 Answers
Find the reason the fuse blew. bridging is a simple bypass and is never good. could have other problems now due to constant voltage with no safety.
Posted on Sep 26, 2014
93 harley battery wont hold a charge
battery could be no good so have it charged and load tested and then you may have a key off abnormal drain on the battery due to a shorted regulator or accessorizes. Remove the main fuse to see if it still drains and if so something that should not be key off draining is the probelm amd if the battery still goes flat you need a new battery most likely.
Apr 23, 2014 | 1993 Harley Davidson FLSTF Fat boy
Battery consistently draining
Most likely you've got something draining the battery. Read this post
http://ricksfreeautorepairadvice.com/battery-dead-morning/
Aug 27, 2017 | 2005 Kia Sedona LX
What is wrong with my 2003 BMW 525i?Battery Drain
excessive power loss due to alternator bad..take to parts store so they can check it..diode trio is bad letting power back thru the alternator..basically it wont shut off now and will kill the battery after several hours..
Dec 26, 2013 | BMW X5 Series Cars & Trucks
Mazda 6 battery drain till battery is flat and wont start is this a common problem easy fix
check that all power is switched off including the boot light. Remove the earth strap on the battery and place an ammeter in the line and see the amp draw to give you some idea of what might be staying on. Is the rear window heater/demister still on.
Apr 03, 2013 | 2006 Mazda 6
How do you recode the radio in my 2005 vw beetle
You can run your radio a number of days and will not run the battery way down. I had a car that did that and each night when I shut the car off I disconnected one fuse and did that till the battery did not run down. It took several times and I would write down the fuse I pulled. I found something was malfunctioning in my air conditioning switch area. My mechanic replaced something and is ok now. Not saying that is your problem.
Apr 03, 2017 | 2005 Volkswagen New Beetle
2008 ford fusion battery drain
there a good and easy way to check if your batterie is broken.
your batterie has some caps on if its 12 volt you have 6 caps.
turn the caps off all.start your engine while looking to your batterie.
when your starting and there comes smoke out,batterie is dead.
you must see good,so one starting and one person checking on smoke.its also a good thing to clean the connections positif and negatif aswel the cable and the batterie itself. if there are not clean and i mean
like silver color. batterie will not charged good.when you got connection,
thats looks like white cool.por some low hot water on it till its gone.
wacht out for your cloding.the white stuff can blowing away by wind,
when it come on your cloding,you will see nothing till next day,
big hole.
Jul 26, 2012 | 2008 Ford Fusion
New altenator and new battery, but if i let sit without starting for a day battery goes completely dead
There is somthing that is not turning off or a short somwhere draing you battery..till you find the problem take the hot cable off the battery so it dont drain it
Mar 13, 2012 | 1982 Ford F 150
My 307 peugeot wont start no power no lights noyhing was runnig fine all day untill i tried it this morning and nothing
May be the battery of your car is got completely drained. sometimes by mistake any of the car lights or ac or any battery consuming accessory remains on.And due to this battery gets completely drained and due to no voltage in battery the car does not start.In some cases the car does not gets turned off.If there is a problem in ignition switch circuit and this also drains the battery.Get the car battery voltage checked.It should be 12 volt if the battery is properly charged.This will let you know what is the problem .Also check the battery connections if its got loose then this can happen.------------- Thanks.
Dec 08, 2010 | 2005 Peugeot 405
My gmas 98 avenger (2.0) wont start. i bought her a batt about 6 mnths ago. it ran fine. but she let it sit for a week, now no start. batt is dead. afteri charge it wont turn or even make a sound, then...
Back to "square one" If battery was drained by a short, etc and sat for a week like that, likely the battery is now doa...Have it tested. Then start checking for source of drain...at this point everything is suspect. Put an ammeter between either battery cable and battery and start pulling fuses till draw is gone. then check system that fuse serves. Yes \, could be a bad alternator but you really should test before wasting time especially if it's not that.
Aug 03, 2009 | 1998 Dodge Avenger
Vehicle Parts & Accessories Logo
43 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
