Question about Mtd 22" Yard Machine Push Mower
Carbaeurator problems - 22" Yard Man push mower
The backside of the carbaeurator on my 22" Yard Man push mower plugs into a plastic tube that goes into the engine. What is that tube called and how hard is it to replace seeing as mine broke about half-way down the tube?
  • 376 Answers
That is the intake tube. You have to remove the rewind starter housing and the armature (what the sparkplug wire is hooked to) and unscrew it. IfI knew the engine model and type numbers, I could tell you the part number for the tube. They are located around the spark plug and stamped into the cover. Model-Type-Code.
Posted on Jun 18, 2009
Find oil plug to drain oil
If there is a drain plug, it's probably under the mower deck and really not of any use. Get 3 or 4 feet of clear plastic tubing small enough to stick down the fill hole and siphon the oil out. You can use an infant nasal bulb to get the siphon started. It works best to set the mower in the back of a pick-up or on a bench so the oil will flow. It's slow but not as messy as turning the mower on its side to drain the oil.
Apr 09, 2014 | Mtd 22" Yard Machine Push Mower
I borrowed my Brothers Tecumseh Yard Machine Push Mower to mow my lawn but the pull cord wont pull. Is there a saftey or something i dont know about ?
There is a little bar up by the handle that you have to pull back toward the handle, this is the dead man lever. When released it will stop the mower by grounding out the ignition coil and braking the engine.
If this is not the problem, then let me know.
I hope this helps.
Aug 09, 2011 | Mtd 22" Yard Machine Push Mower
How much oil goes in a 22'' inch MTD yard machine push mower
Most normal push mowers require 20 ounces of engine oil. I recommend that you use only SAE 30 oil and try to use synthetic.
May 01, 2011 | Mtd 22" Yard Machine Push Mower
My Yard Machine lawn mower stops working. I can start it if I press the gas button a few times but it would stop running right away. The gas is not reaching the engine. I opened the air filter and found...
the red tube should just slide over a tube sticking out of the carburetor or the plastic housing on the breather.all you do is plug it in. if that dont fix it my guess is there is debris in the carburetor that needs to be cleaned. take it apart clean and it should run as like new
Nov 23, 2017 | Mtd 22" Yard Machine Push Mower
Oil coming from line from engine feeding into air
More than likely your air filter is clogged and needs replacing. If that is the situation the carb needs air and is pulling suction on the crankcase breather tube siphoning up oil instead of just burning the vapors. If it was a busted ring the oil would be coming out the exhaust and burning blue smoke.
May 01, 2010 | Mtd 22" Yard Machine Push Mower
Oil change in yard man lawn mower. i am unable to find a drain plug
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 05, 2009 | Mtd 22" Yard Machine Push Mower
Yard man mower 139cc OHV spark plug
You can purchase a boot puller or take a pliers and grab exactly on top of spark plug and pull off. Some do stick on harder than others.
Aug 17, 2009 | Mtd 22" Yard Machine Push Mower
Dumb gasket question
When you take off the carburetor initially, you should change the gasket if it tears or just old looking, your problem is in the carburetor, probably. Take it apart remembering where the parts go. There are some diaphragms and screen, tiny jets and such. They also must be in great condition with no trash. Clean off with starter fluid.
Jun 18, 2009 | Mtd 22" Yard Machine Push Mower
Yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Apr 23, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
244 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
