Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
22hp anti fire solenoid .?
Chock will not work only by hand
Cub motor problem, not turning all the way around. Also have briggs 407777 22hp motor I want to put in it .Problem is how to make electrical connections which wires hook to which
what serial numbers and model numbers??,i might be able to help you now,it would help if i had all the info,,
there is a yellow wire and a black wire on the 22hp ,the yellow is for the generator the black is to shut down the motor,there should be wires going to the starter,they go to the solenoid,,the cub will have alot of wires,if you want to keep the safety switches active,then i need all the info,if you dont,then hook that black wire to a switch and then to ground,hook up the wires to the solenoid the same.
May 08, 2015 | Garden
2010 craftsman 46" w/ kohler 22hp engine, problem: starter solenoid chatters rapidly when switch is turned. starter does not turn. replaced solenoid w/ no change?
the solenoid chatters due to voltage drop. Check battery charge & condition, and check battery terminals and connection to ground and the solenoid.
Nov 08, 2013 | Craftsman Garden
Sticking brake caliper
Alot of things could cause it. If your brakes are binding, then your brake caliper should be inspected to see if the pistons returns or not. Also the flex hose should be checked.
There is a possibility that you need to calibrate the steering angle sensor and the yaw rate sensor. If you have your abs light ON on your instrument cluster, kindly run a scan on the chassis.
Oct 20, 2013 | Chevrolet Cars & Trucks
Petrol Car Engine OFF when Press Escilator
Have you checked the timing? It might be too advanced. I would try to retard it just a little. I would also check for vacuum leaks in any of the hoses going to the carburetor or the distributor.
Apr 22, 2017 | Maruti Cars & Trucks
Kawasaki engine 22 HP replaced with new starter and it still will not start
you need to check for power to the trigger wire to the solenoid a bad safety switch will not send power to the solenoid
Jul 16, 2012 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I want to know the distributor cap firing order along with the firing order on the engine
The ignition order for my 1988 Mitsubishi Mirage is Longest lead to left-hand outer piston, then left-hand inner piston followed by right-hand outer piston then right-hand inner piston., going in an anti-clockwise direction.
Oct 19, 2010 | 1988 Mitsubishi Mirage
My gun just beeps when i pull the trigger even when hooked up to hpa.battery is new.last time i used the gun just before it messed up i had it hooked to o2 and it would fire then beep ,i have a anti syphon...
You have probably messed up your solenoid, did you fire the marker straight up with the o2? I would make sure that all of the board settings are back to factory default especially the dwell and reattempt with compressed air. If the marker is still not firing get your hands on a new solenoid for it.
Sep 09, 2010 | Smart Parts Shocker NXT Paintball Gun
How do you replace the starter on a 2001 Isuzu Rodeo 4cyl 2WD?
Remove the battery earth cable. Engage parking brake and chock the wheels. The starter is on the lower rear left hand side of the engine. Remove the starter supply cable by undoing the 13mm nut on the rear of the solenoid. Unclip the start wire on the side of the solenoid by squeezing and then pulling the connector plug. Undo the mounting bolt on the top of the starter first. and remove. Then the bottom one. Doing it this way round will make it easier to undo the bolts by hand once loosened.
Pull the starter to the front of the car and remove.
Aug 21, 2010 | 2001 Isuzu Rodeo
I have a 125 thumpster it will satart with the chock on and will run with the chock on if i turn the chock of it will die if i try to ride with the chock on it will back fire what do i do
That is a sign of carb problems! You will need to remove it and disasembel it and clean every nook and cranny. Use carb cleaner and a air compresser.
Dec 20, 2009 | 2002 Yamaha TT-R 125
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
