Question about E-Machines eMachines Desktop PC
How do I remove a DVD stuck in the e-machine?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Straighten a paperclip. Near the button there is a tiny little hole. Push straight in and it will force the tray to disengage.
Posted on Jan 29, 2015
VCR tape stuck in machine
First unplug the VCR then you can carefully unscrew the screws that hold the body to the base of your machine and you can carefully remove your tape !?!
Mar 17, 2014 | Zenith XBV442 DVD Player/VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Our dvd is stuck in the player and it cannot be removed.
The dvd tray may have a pin in front, if it does! get a fine screwdriver or needle and push it in until you hear a click, the tray should pop open. If does not then the machine needs to be taken apart to access your dvd.
Dec 30, 2010 | Toshiba SD-V291 DVD Player/VCR
A dvd is stuck in the machine. The dvd plays fine, but will not eject.
I've had this problem once. You should carefully open up the casing and remove the disc manually. Close the cabinet and you're back in business.
Nov 10, 2010 | Jwin JD-VD130 DVD Player
Dvd stuck in machine will not play or open to remove movie
there might be something hooking the disc tray that is prevent it from opening.
The solution to this problem now is to, get a screw driver, unscrew the screws on the player, open the player cover so that you can gain access to the disc stuck inside, remove the disc and check for what's preventing the player from ejecting.
Take care.
May 30, 2010 | Panasonic DVD-S35 DVD Player
DVD-R disc stuck in machine; powers on/off repeatedly
under the dvd player there is a lever you can slide with a knife and it will open it up
Jun 17, 2008 | Philips DVDR3455/37 DVD Recorder/HDD...
DVD stuck in player with no power
you have to unpower it and remove the screws from the cover and then remove the screws off the cdrom/dvd player.
Apr 08, 2008 | Televison & Video
Dvd stuck in dvd
Lay the TV, face down on a folded towel. Remove all the screws. Note: there is one perimeter screw with machine threads; all the others are the same.
Remove the four black screws from this area:
Then you can pop the back loose and slide it towards the end where the black screws were. It just lifts off and there are no wires attached.
Now you can see the DVD player. I used the end of a plastic pen to shove against the edge of the DVD that you can see through this slot.
Press on the DVD's edge until you see it come out the entry slot.
You can see the DVD slide out the entry slot as you are pushing.
When done, slide the back into place and replace the screws.
Dec 31, 2007 | RCA 15L500TD 15 in. TV/DVD Combo
Philips 642 problem
when mine has frozen up i push and hold the power/standby button for ten seconds then release then push it again and it comes on and opens as usual.  or do you mean the disc is stuck in the machine after the door opens?  maybe open the machine it could be inside.
Dec 23, 2007 | Philips DVP642 DVD Player
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
