Question about GE GSH22JFR Side by Side Refrigerator
Not cooling properly GE TFX20JR
Fridge and freezer are not cooling properly
  • jbaita Jun 19, 2009
    there was no crackling or sizzling in the freezer, also i do not beleive the compressor started back up.
    Please advise! thank you
  • GE Master
  • 4,655 Answers
Your refrigerator has a defrost thermostat inside the fresh food section behind the light cover and control panel. Need you to turn it clockwise slowly until the compressor stops. Leave it like that and after 30 minutes or less it does not restart you will need to replace the timer. The defrost timer is part number WR9X489
You should hear sounds from freezer with door open like sizzling or crackling. That would be the defrost working. If there is no defrost during this time. let me know so we can look into the defrost element and defrost thermostat as possible problems. Visit my site and enter the model or part number into search feature. That takes you to your model. Any questions or help from me, just let me know, Thanks, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Posted on Jun 18, 2009
  • John Tripp
    John Tripp Jun 19, 2009
    OK, still the timer should turn the refrigerator back on. You can turn it again until the compressor starts. The thing is I do think there is a problem with the timer. The clock should cycle the defrost every 8 to 10 hours and be in defrost for about 20 minutes. If you feel the timer is OK then we need to have a look at the defrost element inside the back panel of freezer. Unplug the refrigerator before working on the electrical parts. Want you to check the defrost heater by removing one wire and check the continuity between the two ends of the heater. Look at the defrost element for signs of deformity. After the freezer reaches 50 degrees the contacts in the defrost thermostat open and you will not show any continuity through it unless it is near freezing while testing withe an ohm meter or multimeter. Let me know next what you find. Or if you have more questions I'm here if you need me. Thanks Sea Breeze
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
GE 19.7 TFX20JR not cooling or freezing
I think you fridge is low an gas, refill it
Mar 14, 2013 | GE Refrigerators
GE TFX20JR
how is the freezer? if it is ok is the freezer back panel full of frost if so then you have a defrost problem and the ge is really good for the heating elements to go bad
Jun 26, 2009 | GE GSH22JFR Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge side by side not cooling, freezer act like fridge
Sounds as tho your compressor is bad if it is still under warrenty take it to the place of purchase.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Nov 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
1,857 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
