Question about Zenith P42W46X 42 in. Plasma EDTV
No picture will turn on but have no picture. tried changing channels but still to no avail. any thoughts
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
Dec 29, 2012 | RCA 27V520T 27" TV
"No Signal" on the TV
have you try to reprogram using menu setup/auto channel /before programming in tunner set upcoose cable
after reprogram select channel 3
hope that will helps
regards Alan
May 11, 2010 | Vizio L37 Television
Sanyo Television DP26649 messing up
Don't know about losing the channel settings but there is a button on the remote in the middle at the top that says "PIX SHAPE". You can change the size of the picture by choosing several different options. Hope this helps. PJ in Mississippi
Dec 28, 2009 | Sanyo DP26649 26 in. TV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Satelite receiver stuck on one channel.
Go to the menu settings. See if there is an option for 'autoprogramming" It should search all available channels.
May 28, 2009 | Televison & Video
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
Television: no picture, good audio
screen control is too high
Nov 11, 2007 | Televison & Video
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Zenith P42W46X 42 in. Plasma EDTV Logo
29 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
