Question about Waterway Above Ground Hi Flo Pump
Runs fine in low speed on & off rapidly in high speed
  • 2,760 Answers
By saying this are you sure the motor is turning on/off ? or could it be that water discharge seems on/off , because this could be a pump condition called CAVITATION this is a condition when pump is turning so fast that water doesn't have time to reflood the pumps impeller and at outlet seems like the water is going on/off makes a bit more noise and foam as well due to water smashing into it's self over and over , most cavitation's are caused by a restriction in the inlet line to pump but can be also a indication of a pump head wearing down too , takes a exp pool tech to know the difference , if the motor is truly turning on/off fastly ck your electric connections to be sure there tight !! other than that its all done by the controller boards and those you can only replace , theres nothing to "fix" on them
Posted on Aug 26, 2015
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
When you reconnect battery how much time does it take for cpu to program itself ?
All makes & models are different. You have to drive the car at several miles high speed, than several miles low speed & repeat the process. That usually covers most vehicle. But just drive normally at high & low speeds and soon enough you'll be good to go. Does not do the clock & radio for you. That your on your own.
Sep 19, 2015 | Cars & Trucks
Runs fine on low speed hums on high speed (turns slowly) is it a capacitor problem, internal windings or controller?
Motor itself is the culprit.
Capacitor helps the motor to start spinning from a dead stop, so NO, it is not a capacitor problem.
Probably high speed windings. Means - New Motor needed.
Another possibility, is the controller could be sending power to "Both" sides of the windings: High speed & Low speed at the same time. But normally when this happens, you hear a loud buzz type of sound, motor will spin slowly - if at all.
Good Luck
Mar 11, 2015 | Pool & Spa
I have a Balboa 500Z and everything works fine except the two speeds on the pump are backwards. When it is in normal heating mode the pump runs on high insted of low.
Switch the black & red wires, normally these are connected to the speed ports of the motor. But.... be careful! Electricity is color blind and does not care what color wire it is traveling through. So therefore confirm that the black & red wires are on High & Low marked lugs. Then once that is confirmed, then switch the position of those two wires.
Feb 08, 2013 | Balboa Instruments Duplex Digital Panel 2...
System not cooling properly. Two speed compressor
According to the reading sound like compressor is working fine .There are other issue that contribute to no cooling and the main one is dirty filters so check your filter to see if it's dirty and clean or replaced it .
If filter is fine then you might have dirty evaporator or condenser coil so clean those out too .
Does this unit have 2 compressor and if it does is the 2 compressor running
May 22, 2017 | Carrier 38CKC060 Air Conditioner
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
My eager ****** chain saw will not stay running ?
The 3 adjustment screws are Idle, high and low.
First figure out which screws are which adjustment. Tighten the screws then turn them 1 full turn.
Then start the saw and get it warmed up. Work on the high adjustment. This does take a little while. after you get the saw running at high speed work on the low speed.
Apr 25, 2009 | McCulloch MC1275 Steam Vacuum
Waterway Above Ground Hi Flo Pump Logo
301 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
