Question about Westinghouse Televison & Video
Westinghouse tv input source box stuck on screen
My 32" Westinghouse TV input source box is stuck on the screen and won't go away. If I hit "ok" on HDMI, it goes away for 2 seconds and reappears.
4 Suggested Answers
westytech
  • 120 Answers
SOURCE: 32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Posted on Feb 04, 2010
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
Zephyr0u812
  • 27 Answers
SOURCE: WESTINGHOUSE TV 32 IN LCD TURNS ON FINE, SECONDS
The right thing to do is to get a new power supply.
You probably have 1 bad inverter transformer. They are available on eBay for under $20. The 1st 5 characters on the transformer should be the part number. 4301H, 6601H, etc...
The issue I have had is that even after replacing the inverter transformer, the same problem exists. The solution I found is to remove all of the blue capacitors around inverter transformers.
This DOES create a danger as it eliminates the over current protection feature built into the power supply.
I do not recommend this method as is creates a fire hazard in the event of another inverter transformer failure.
It will solve the problem though...
you didn't hear it from me lol
Posted on Dec 15, 2012
Hello am trying to auto scan my flat screen tv it is a Westinghouse 32 .but I can't get the remote to the channel setup menu
Hello. If the TV isn't on the antenna input, you won't be able to get to the scan menu. I am guessing that is the problem. Use the source or input button to make sure you are on the correct input. Hope this helps!
Jul 31, 2016 | Westinghouse Televison & Video
Westinghouse 32' flat screen tv .red power light comes on .when turned on screen shows westinghouse symble then fades away .green light stays on then tv turns its self off.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 22, 2016 | Westinghouse Televison & Video
How do i get my westinghouse to recieve signal it shows on the tv no signal and on the box it says that the tv does have a signal
Make sure you have the TV tuned to the proper source.
My TV has multiple input sources ranging from the cable box to various AV and gaming equipment and I must select the right input source in order for the TV to receive a signal.
On my controller, there is a button at the top for selecting the input source. I can cycle through all sources by pressing that button. If you're using a programmable universal controller, that function may not be programmed into the universal controller so you may need to use the original controller that came with the TV.
If, after you've cycled through all of your available sources and still get no signal, check and see if a wire has come loose between your cable box and TV, either at the cable box end or the TV end.
Hope this helps.
Sep 09, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a westinghouse flat screen tv model sk32h240s that has no picture but sound works. I have replaced a bad transformer and checked and replaced all the capacitors that were bad. What else should
Depends on what type of input your using. Maybe try dif cord( hdmi,component video or composite video) or try dif input on tv. Verify source has video out on dif tv or try dif source.
Jul 25, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Apr 06, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse tv won`t turn on. blue light is lit
westinghouse flat screen ...blue light on lower part...can not get to stay on tv and no sound...what button so i push to go back to tv
Feb 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
INSIGNIA PORTABLE DVD
Use the A/V outs to the composite cable and connect to your Westinghouse A/V jacks.
On the Insignia player, press the Source button until you see A/V OUT on the insignia players screen.
Set your Westinghouse to the A/V input port you have connected the Insignia player to and VIOLA...you should have picture and sound.
Nov 11, 2007 | Insignia IS-PDVD10 Portable DVD Player
Westinghouse ltv-19w6 source won't change
Have you tried to click the source button on the tv? It is the second button from the bottom on the right hand side of the screen.
I doubt your tv/monitor is turning off, it just isn't getting any input. D-Sub is the "pc monitor part".
Try clicking that button, give it sec, the hit it again. It will go through all of it inputs. If TV is what you are trying to find, it is directly after the Video input (green letters, top right hand side of the screen.) Keep hitting the button until TV shows up.
Good Luck!
Oct 23, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Televison & Video Logo
327 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
