Question about Sony Cdx-606 10 Disc Cd Changer
Disk does not load but makes a clicking sound
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
I installed a buffalo external hard drive 1.5tb, at first i can access the drive but now it's was making a weird clicking sound, and i can't access the drive.All it says loading and the my computer says...
Sounds like the hard drive is faulty. A clicking noise would indicate that the drive's heads are failing at reading the disk (thus retrying again and again). And of course, while this happens, your computer is waiting for the disk to respond (so you experience a long period of time where the computer doesn't respond as well).
If the disk is still under warranty, you can (and should) have it replaced. Hopefully you have a backup of all the important files in it.
Mar 13, 2011 | Computers & Internet
When load a disk xbox 360 makes a clicking noise and says open tray on the screen
Something is most likely wrong with your disc tray.
Try a new disc, and if the problem persists, I would call xbox support.
May 19, 2010 | Microsoft Xbox 360 Console
Unit comes on and it takes the disk ok but then thats it
Make sure the drive to the Wii is upside down so its facing the ground and shake the Wii cause there may be loose debris in the drive.
If nothing comes out then the drive is bad. If debris comes out then try to load a game and if it doesn't load then the drive is still bad.
Nov 28, 2009 | Nintendo Wii Console
When i try to load some games it will make a clicking sound right before trying to spin the disc and it wont load the games
does it do that when you try to use the disk drive for other cd's. if so your disk drive is going. clean the cd even small about of dirt on cd will prevent it from working. wipe cd with clean dry cloth, get off any finger prints.
Jun 10, 2009 | Ubi Soft Entertainment Rainbow Six: Vegas...
I have the ego 1TB external hard drive. My computer does not know its there. When I plug it in. the Mozy icon appears in my computer but I do not see a drive for the HD. When I turn on the external HD the...
right click on my computer and click the manage. a pop up windows appears then click disk managment on left pannal, it will give you the option to resolve you problem.
Oct 21, 2008 | Computers & Internet
Reinstalling the disk
If you mean that you removed the software drivers for the sound card, yes you can re-install the drivers if you have the CD disk that contains the driver software. Carefull though, make sure your just loading the driver software for the sound card and not re-insatlling the whole operating system!
Oct 16, 2008 | E-Machines eMachines Desktop PC
Error message
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Symphonic WF803 DVD Player/VCR
I'm having a problem with my CDJ 800. Loading ejecting
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Dvd won't load
open it and check for a broken part in one of the gears that operate the drive. if the unit is under warranty, take it back rather than try to fix it.
either something is in the mechanical portion of the unit, or it is badly worn.
i would suspect a broken part from the noise issue/ clicking sounds.
the read head runs on a track and could be jammed up, unable to run to access the directory of the disc. inspect what you can get to, and hopefully that will be a simple fix.
good luck
mark
Jan 05, 2008 | Symphonic SD200E
Sony Cdx-606 10 Disc Cd Changer Logo
27 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
