SYLVANIA ALARM CLOCK RADIO SCR1206B - Audio Players & Recorders
How can I shut off the alarm on an unidentified clock radio?
Barbra; Alarm clock shut off and snooze button are not the same thing, if you want alarm off, use the slide switch, slide switch to alarm off position.
How To Set TIME ALARM CLOCK of VINTAGE Old LLOYD J375 771A RADIO AM FM...
How To Turn Off The Alarm On The RCA Talking Clock
Jan 25, 2016 | Audio Players & Recorders
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
Set time on the sylvania Bluetooth radio scr1996-pl
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Mar 08, 2015 | Radio Communications
How does one disengage the alarm on sylvania pll alarm clock radio model scr 1053
There should be an option during initial set up that allows you to disable the alarm function. You may have to disconnect power, then apply power again to repeat set up.
Jan 08, 2015 | Sylvania Audio Players & Recorders
Setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
Oct 21, 2008 | RCA RP5440 Clock Radio
"unset" the alarm on Timex T300T clock radio
When you set the alarm you pressed aburron that said 'radio' and/or 'buzzer' then programmed the time. Just press the buttons again and the alarm will no longer sound. Looking at the dial at the top of the lcd screen you will see the word buzzser or radfio if the alarm is enabled. Pressing buzzer or radio on the side will remove the word and no more alarm!!
Luck----
Jul 30, 2008 | Timex Auto-Set Dual Alarm Digital Clock...
Set Clock
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
103 people viewed this question
 Grubhead
Grubhead
