Question about Kenmore Refrigerators
My kenmore elite refridgerator is not cooling
We had a power outage last night and now the temp isn't cooling even when we press colder on the gauge
peyton32034
  • 410 Answers
SOURCE: kenmore elite coldspot 106.55606400 --fridge not cold enough --
37 is the atual temperature that your trying to acheive. so to make it colder you would go down to 36 which is one degree cooler. hope that helps. thx peyton
Posted on Jan 31, 2009
SOURCE: Newer kenmore elite trio refridgerator not cooling
The repair person came and in my case it was a start capacitator connected to the compressor. When he replaced the start capacitator the compressor came on immediately and started working. The charge $ 240 (Flat Rate) for the fix. The repair person told me its a universal start capacitator which I found online for $29. Worth trying to fix yourself before paying $240 if your a handy person.
Posted on Feb 10, 2009
philbran
  • 242 Answers
SOURCE: Power outage caused by fridge to quit
OUCH! , the partial digit display is an error code that has a meaning and they are never good , these units I have seen/repaired many times but I do not have the code book to determine it.
Try holding down the power freeze and power cool at the same time until you get something. If the unit is ok it will reset and hopefully be fine , if you still get a code these units have longer warranty's and could be repaired with no charge.
Phil
Posted on Apr 14, 2009
SOURCE: refrig not cooling even with power cool use
Change sensor on refrig side and the main board
Posted on Jun 07, 2009
aasc
  • 1606 Answers
SOURCE: My Kenmore Elite trio has stopped cooling the
If you see frost on the back wall inside the freezer , then your condensor is working , which indicates you have a defrost problem .
Posted on Jul 11, 2009
Why does my Kenmore Elite 596.75524400 refrigerator not cool or freeze but appear to be functioning?
Keep a thermometer in there. Adjust the temp and wait 24 hrs. Is 1 colder or is 10?
Jul 15, 2014 | Kenmore Refrigerators
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
Kenmore Elite 596.75523400, the refridgerator is working but the freezer isn't. The freezer defrosted but the freezer fan is working. Thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer side and Refridgerator side are not cooling food
I would find out what it would cost to fix it. If the cost is more than the price of a new one then I would get a new one.
Aug 23, 2009 | Kenmore 51562 / 51564 / 51569
Stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
Phil
Apr 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Elite 73952 will not start
sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Mar 11, 2009 | Kenmore Elite 45986 Front Load Washer
Resetting my refrigerator
It is possible that there is no reset button.
Power outages or spikes usually affect the compressor which provides the refridgeration. It is possible that it may have got damaged. The spike is where the power have gone off but come back on too quickly causing. Spikes usually affect motors, pumps and compressors.
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
15 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
