Question about Honeywell 3820 Computers & Internet
Follett 6300 barcode scanner manuel - 3820 Honeywell Computers & Internet
3 Suggested Answers
SOURCE: TK-1000
I have a tk-1000 barcode scanner hooked up to me computer for library use. I also have right on progamm on my computer. i want to ask if i can used it togather with my scanner tk1000
Posted on Aug 26, 2009
issken
  • 1472 Answers
SOURCE: My 3820 will no longer
srodgers609
One of the problems I had with my scanner is that the USB port that I had the scanner in when bad. My scanner cable was a little short and it put extra pressure on the port. After time some of the connections in the port broke. To fix the problem I had to replace the USB card in the system.
So I would recommend that you tryu the scanner on another computer and/or another USB controller to see if it works properly. If it does you know that it is the USB port. If it does not then I would look at the cable of the scanner.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 25, 2011
Follett dolphin phd
So, I had a large scan.log file which I would have lost if I followed the instructions above. Instead hold the shift, on scan and bksp buttons simultaneously. The device will reboot with your file still functional!
Aug 27, 2013 | Computers & Internet
My 3820 will no longer scan Follett barcodes. It makes several error beeps every time I try to scan anything
srodgers609
Issken
Aug 25, 2011 | Honeywell 3820 Wireless Handheld Barcode...
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
The laser is not working on my Follett PHD- Dolphin scanner
You need to do a system hardware reset. Do this by remove battery and find small pin hole just below the battery terminal single pin side. It may be covered over by black sticky pad. Get paper clip wire and put through hole to you feel small click. Hold down for 10 sec and then put battery back in to see the unit run a rebooting procress.
Hope this fix it
Jun 09, 2009 | Computers & Internet
TK-1000
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Aug 27, 2008 | Computers & Internet
Scanner doesn't work
Sccaner open through screew driver & properly wash Logic board with ethiel alkohal. Plz properly check connection streep wire so connected with the warming lamp to logic board.
May 16, 2008 | Dolphin Computers & Internet
Optical Drive not working.
Does anyone have a manuel for these LS 9100's barcoding machines?
May 01, 2008 | Computers & Internet
Ls 9100
The first thing you need to do is set the LS9100 to know it's connected to a synapse cable. Scan the "set all defaults" barcode and then the "set synpase host" barcode. Once you have done this you can program the unit for the specific synpase cable your purchase, such as USB, PS/2, etc.
Oct 06, 2007 | Symbol PDT6842-NIS632EU Portable Data...
The scanners won't scan information after being programmed
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Jul 06, 2007 | Symbol Hotshot LS2106 Handheld
Computers & Internet Logo
1,081 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
ray gallant
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
