Question about Brother PRCFH1 ORIGINAL Cap Holding Hat Hoop Frame, 2x5" Embroidery Above Brim, for All PR600 PR620, PR650, Babylock EMP6 BMP8 BMP9, 6 Needle Machines
Cap frame isn't reconagnized by emp6 machine
Frame is on machine correctly but the emb. machine does not reconanize the frame. why?
Anyone have a Baby Lock EMP6 simply freeze while sewing and display a "lost communication" message?
Sounds Like It Needs An Upgrade (more Info Needed Please!!)did you try to upgrade via laptop or computer (may be a bug in the software try to go into settings do a reset !! (more info needed Please!! ) Pleasure To Help You Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Power Computers & Internet
Baby Lock EMP6 needle is hitting the bobbin system and breaking up,
Your machine has been knocked out of time. Take it for service.
May 05, 2017 | Baby Lock Sewing Machines
I have a baby lock emp6 it stops and says main motor lock
the motor on the machine could be going out, the machine should be checked..
Dec 16, 2014 | Baby Lock Sewing Machines
Babylock emp6 power supply voltage error
The Instruction and Reference Guide for the EMP6 says to consult your nearest authorized dealer.
If you are a do it yourselfer who is knowledgeable about electrical matters and have electrical repair skills, you will find a repair method in this manual http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf which will probably be very close if not identical to the method for the EMP6.
If you are not experienced with electrical repairs, I would advise you not to attempt the repair, but at least by looking in the manual you will know what the repair person has to do.
Jan 20, 2014 | Office Equipment & Supplies
The carriage on my babylock EMP6 is clicking and will not align.
Sounds like your carriage gears are slipping as though there is something blocking the carriage from moving. Could be the carriage is not seating properly.
Jan 12, 2014 | Baby Lock Sewing Machines
Husqvarna Scandinavia 300 not embroidering desgin correctly.
more than likely its the main pc board but if you had another emb unit you could put that on your machine and if it works fine then its the board inside the emb unit
Apr 16, 2009 | Husqvarna Sewing Machines
Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
Jan 08, 2009 | SmartParts SPX8 Digital Picture Frame
Brother PRCFH1 ORIGINAL Cap Holding Hat Hoop Frame, 2x5" Embroidery Above Brim, for All PR600 PR620, PR650, Babylock EMP6 BMP8 BMP9, 6 Needle Machines Logo
98 people viewed this question
Top Brother Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Brother Clothing Accessory Expert? Answer questions, earn points and help others
