Question about Dell Inspiron 6400 Notebook
  • 24 Answers
If you have another computer in your home unplug the keyboard and try the locked keyboard on that computer, then vice versa plug the other keyboard in that pc and see if another KB works. If it still does not work you can assume that it no longer works. I'd would then call dell let them know and if your still under waranty they will send you out another KB.
Posted on Nov 15, 2007
0 characters
3 Points
Turn off num lock laptop
Hi aidatul, please try these steps
1. Choose Start---Control Panel---Ease of Access---Ease of Access Center.
2.Click the Start On-Screen Keyboard button.
3. Click on the 'num lock' key once to turn it off
Close the keyboard and try to type.
Jun 19, 2013 | MSI PC Laptops
Keyboard locked on m14x laptop
replace the key board it doesn't cost so much
Mar 10, 2012 | Dell Alienware M14x Notebook
Im using my mom Dell latitude D600 PC Laptop and It was working good then all of sudden S key wont Stop typing itself Till we press "r or T" it making it hard when it pops up out the blue. it...
It seems that your laptop keyboard is not working any more. you need to buy new keyboard for ur laptop or if you want to use usb keyboard then remove this keyboard's cable, connect your usb keyboard it will work.
Aug 21, 2011 | Dell Latitude D600 Notebook
Keyboard Problems on my Dell Inspiron 6400,
change your settings to less sensitive in the mouse and cursor control panel
Mar 12, 2010 | PC Laptops
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
Dell Inspiron 1440 keyboard keys issue
you need to isolate this issue first.
where are you typing? inside IE or in MSWord?
If both has issues then try typing in the DOS Command Window. If same issue try to boot in safe mode and check if you will still be getting same issue in safe mode. If all yes try to check the bios and update it by downloading the latest bios version from the support site from dell.
Oct 06, 2009 | Dell PC Laptops
Keyboard is locked down how do I unlock it.
Please find the attached link;
that must take care of your query.
Anirban Mazumdar
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1318 Keyboard problem
If it is still under warranty just call Dell and have them send a replacement keyboard. If not, either try cleaning her laptop keyboard or just pick up a new one off some place like ebay for about $10.00 with free shipping.
Jun 05, 2009 | Dell Inspiron 1318 Notebook
Inspiron 2650 Laptop keyboard is locked.
If the keyboard is locked ALL the time, try unpluging the power supply, remove the battery, then push and hold the power button and any key on the keyboard for at least 30 seconds. then reinstall the battery, plug the pwoer cord back in and reboot it.
I had the same problem and that is what the DELL techs had me do. I had the problemm frequently for a while and then it just quit recurring. I haven't had the problem for a long time now.
I hope this helps.
Don Jones
Dec 17, 2008 | Dell Inspiron 2650 Notebook
Try this:
Shut down, unplug the AC adaptor, removed the battery, and hold the power button for up to 1 minute to discharge.
Make sure there are no stuck keys.
Apr 08, 2008 | Dell Inspiron 2650 Notebook
Dell Inspiron 6400 Notebook Logo
1,244 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
