Question about Amana PTH074B35AE Heat Pump Air Conditioner
Amana ptac error code br cant get off - Amana PTH074B35AE Heat Pump Air Conditioner
5 Suggested Answers
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 142 Answers
SOURCE: Amana PTAC ptc093d35ar, when i
H1=High voltage protection engaged. Power supply voltage is too high. Check for incoming power at correct voltage.
Posted on Feb 10, 2009
james3751
  • 614 Answers
SOURCE: NEED DIAGNOSTIC CODES FOR AMANA PTACS DIGASMART
Goodman Industries has purchased Amana. So go to Goodman website for info.
Posted on Dec 17, 2009
Where can I find a troubleshooting manual for the DS01E amana t-sta?
http://www.amana-ptac.com/Portals/3/PTAC/PDF/DigiSmart%20DT%20DS%20DD%20Wireless%20EMS%20Installation%20Instructions%202010.pdf
Feb 19, 2015 | Amana DS01E - DigiStat Thermostat with...
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
2,978 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
