Question about Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System
My panasonic phone 6.0plus works but wont ring
Works but will not work
Answer phone from any extension
Pickup code from any extension. *4001 works if your incoming calls are in ring group 1. *41 ext works if a specific phone is ringing and *42 works if the external pager is ringing.
Carl
Dec 20, 2010 | Panasonic KXDT321 Phone
Wont display caller id
A Panasonic phone needs 3 things to display CID, CID service, programming, and a ringing phone.
When you are on an outside line, does the CID display? If it does, then you just need to program the phone to ring. If it doesn't, start looking for hardware and programming. The card required ends in 93.
Carl
Dec 19, 2010 | Panasonic KXDT346 Phone
Hello, I'm trying to turn the ringer off some of the phones at my work. We have panasonic kx-t7630 phones. Are you able to help me please?
When you bought the phone system, it was either installed by a professional installer, or you got some sort of instructions. A Panasonic phone system of the TDA/TDE/NCP type rings phones by Incoming Call Distribution Groups (ICD). The main group is 1 and usually is numbered 601. Extensions are members of an ICD group(s) and the number of rings can be programmed for No Ring, Immediate ring, or delayed rings of 1-6.
You can turn off the ringing, but keep in mind that CallerID only displays on a ringing phone or after you answer it. So, if you somehow have access to program 620 and 621, then you can change it from a phone, if not, you'll need access to the maintenance console of your particular phone system.
I don't wish navigating in 620/621 from a phone on my worst enemy and it's beyond the scope of a free forum to instruct you on how it works. I suggest you call your Panasonic service tech.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
The phone does not ring. How do you turn the ringer back on? The phone model is a hybrid system kx77020.
There's a ringer adjustment on the side of the phone. Does it ring in another jack? Does another phone ring in this jack? Panasonic system ringing is controlled by system programming, usually 408-410 or somewhere near there. If the phone works in another jack or another phone works in this jack, then you need to either turn on the ringer or turn on ringing at that port.
You may have to find the programming in the manual, or call your service tech.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
Two phonelines no longer accessible. Using Panasonic KX-T7730 with a Panasonic KX-TES824 system. Lines were working fine and have now disappeared. They don't ring in and I can't ring out on them. ...
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Oct 09, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic phone rings but line is silent and can't make calls
Tossed out the phone and bought a new much better Uniden. All works great now.
Aug 28, 2009 | Panasonic Lands Phones
Phone wont talk--it has talkingidfeatures
The ringer has to be on first. Usually the unit announces the caller’s name after the 2nd ring. If you turn on the answering system and set the ring count to “2” the unit does not announce the caller’s name. Set it for more than 2 rings for name announcement.
Jul 16, 2008 | Panasonic KX-TG5632 Phone
Phone dead. no ring no dialer tone
This phone is made to work on a Panasonic phone system. Are you connecting it to a Panasonic phone system or just a normal phone line?
If you do not have a Panasonic phone system I doubt this phone will do anything (just as you describe) If you do have a Panasonic system do you have other phones that start with KX-T7??? on the system and have you tried this phone in one of the ports another phone is currently working on?
Oct 10, 2007 | Panasonic KX-T7630 Corded Phone
CALLER ID NOT WORKING
not only Panasonic, most other brand phones imported from other countries wont work in in India ( caller ID). Panasonic phones of Panasonic India, will work.I think panasonic has to explain this. if there are networks which does not support this equipment, atleast they should mention this is their booklets, to avoid users roam around telecom offices. To my understanding, all the land phones of BSNL through out India are caller ID enabled by default and is free!.
Aug 19, 2007 | Panasonic KX-TG2632W Phone
Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System Logo
14 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
