Question about Sharper Image Wireless In / Out Door Speaker &power Supply Ct413 1 Single Unit
I don't know how to pair my esi p410 - Sharper Image Wireless In / Out Door Speaker &power Supply Ct413 1 Single Unit
I've successfully paired the peaker but no sound is coming out
might I ask how do you know you were successfull if no sound is forth coming .
Mar 31, 2015 | THE SHARPER IMAGE ESI-P400 Freedom Premium...
Sharper image freedom Bluetooth model number ESI-P400 how to put in pairing mode.
To pair your device with The Sharper Image Freedom:
  1. Make sure your device has Bluetooth capability.
  2. Slide the POWER switch to turn on the Freedom, indicator will begin to flash.
  3. Follow the instructions of your device to pair the unit.
  4. Pair your device with the unit by selecting FREEDOM from your Bluetooth listings on your device or selecting YES. If prompted, enter "0000" as the passcode.
  5. Press play on your device and use controls on the unit to adjust desired volume.
Note: Once you have successfully paired your device, you typically will not need to repeat the above steps. Please ensure the Line-In cable is unplugged, the unit source is set to Bluetooth and your device has Bluetooth enabled.
Note: The effective Bluetooth range of the Freedom is approximately 30 feet.
Nov 19, 2013 | Radio Communications
Sharper image freedom Bluetooth speaker model ESI-P400 discovery mode button sequence
I want to know about rate and process of esi deduction
Employee's having gross salary of Rs-10000/- or less are eligible for ESI scheme .It means they are covered under ESI scheme while others not.
The rate is
4.75% for employer&
1.75% for employee
of the gross salary
Jun 10, 2010 | Computers & Internet
2003 deville I have rough idling, surging and then lowering of idle. A P410 code comes up. What is this and how do I repair it?
P410 code secondary air injection malfunction
It could be internal head cylinder problem
I would have it checked out
Mar 10, 2010 | 2003 Cadillac Deville
The voicemail light is fully lit(NOT FLASHING)it's not going away
First off we need to know what color it is.
Green-Dial "0" from the problem phone and that should clear it.
Red-Dial "Feature 99 Feature". If that does not work.
Leave a message in that users mailbox. From that users phone check and delete that message.
If neither of these operations work then you may have a bad port which means you may need a new station card. The part is an ESI(8)-U10-ETU, ESIB(8)-U10-ETU or an ESIE(8)-U10-ETU. The U10 might be different.
Let me know how these options work.
Nov 17, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Nov 17, 2009 | Pioneer DEH-P410
Sharper Image Wireless In / Out Door Speaker &power Supply Ct413 1 Single Unit Logo
Top Sharper Image Televison & Video Experts
ray gallant
Electro Med Services...
Are you a Sharper Image Televison and Video Expert? Answer questions, earn points and help others
