Question about Home
My toilet has a big crack going down the back of it and water is leaking when it is being flushed
    Problem Solver:
  • 4 Answers
There is only one solution to this problem and that is to replace the toilet.
Posted on Jun 20, 2009
Installed a new toilet this morning. Filled it and no leaks. Flushed the toilet and water spewed out the bottom of the back. How do we fix?
water in the bowl should not leak. but when you flush it it goes out the bottom into the drain. between the toilet and drain pipe there should be a wax ring gasket to seal the toilet to the floor drain if this wax gasket is damaged it will leak. replace with a thicker wax ring and after you put the toilet back in place sit on it to be sure it has smashed into the wax ring. and put nuts back on and tighten. do not over tighten sand crack the porcelain. this should fix your problem.
Jan 09, 2016 | Home
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Delta Home
Flush the toilet, toilet fill up, but water does stay in the bowl
Is this a new toilet. If so, the design is such that the trap in the bottom side of the toilet is lower, thus keeping less in the tank. If not a new one, then you may have a crack in the porcelain that is allowing water to leak into the drain. I am assuming it lowers to a certain point and then stops. Let me know back.
Mar 28, 2013 | Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Kohler one piece toilet. it is leaking around the bottom of the toilet but if I put the water in the back of the tank myself, it doesn't leak
if its leaking from bottom of toilet on the floor. its the wax ring that may be bad, if it does this when flushing it is either cracked or the wax ring under toilet is bad.
Mar 26, 2012 | Kohler Home
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
A small leak under the toilette, the seal has been changed many times and the toilette has even been replaced. Plumber says deffective toilettes? The leak seems to only happen when or after it is...
I've installed a lot of Toto toilets and have had few leaks but, not from the one piece toilets. It might be a problem toilet but, I would be sure the drain is not blocked causing a small back up after the flush.I have seen this happen many times. The toilet can be pulled and a 5gallon bucket of water can be poured down the drain to test this before replacing the toilet. also be sure water is not spraying on the top of the tank lid and leaking down the back of the toilet.If you flush the toilet with the lid off it should be easy to see if that the problem. hope this helps.
Dec 21, 2010 | Toto ULTIMATE ROUND FRONT ONE PIECE TOILET...
Leak at water supply into tank.
Seams like you have a hair line crack in the intake pipe. I would recomend replaceing it to solve your problem.
Sep 07, 2009 | Home
Super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Home Logo
54 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
