Question about Wolfgang Puck Coffee Makers & Espresso Machines
Coffee maker won't come on
I hit the on button and it doesn't do anything.
mlake33
  • 427 Answers
SOURCE: Coffee maker not brewing after changing water filter
Dis asselble the coffee maker and make sure there arent any coffee grinds stuck in the grinder, this is the usuall problem to coffee makers after some time.
Posted on Apr 29, 2008
  • 188 Answers
SOURCE: coffee maker hit or miss on dispensing the coffee.
You have a short , or bad connection in the lid switch. Probally cheeper to buy a new coffee pot than fit it????
Posted on Jan 30, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Posted on Mar 09, 2009
heatman101
  • 43501 Answers
SOURCE: The blue light on the left doesn't light up.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 03, 2011
heatman101
  • 43501 Answers
SOURCE: My b40 Keurig coffee maker
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 04, 2011
Coffee water won't flow
You probably have hard water deposits in the tubing. Run a couple tanks of vinegar through the machine on a brew cycle. Then flush with a couple tanks of water.
Aug 16, 2012 | Mr. Coffee Bvmcejx33
MY Keurig says "Ready to
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 17, 2011 | Keurig B100 Coffee Maker
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
Our Keurig coffee maker does not work properly. When we try to use it and select which amount to make (from the free small buttons), it goes down the list fo selection, such as the temperature of the...
It sounds like your menu button (Black) is being hit first. Is the button stuck down or has anything been spilled on the control area. The buttons may be shorting out and being triggered inadvertently.
Feb 06, 2010 | Keurig B60 Coffee Maker
It only makes one size coffee. When you hit the
my machine is the antony worrall thompson espresso coffee maker breville
Nov 22, 2009 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Wolfgang Puck Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wolfgang Puck Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
