Question about Garden
20 HP eng repair manual briggs and stratton - Garden
  • 7 Answers
SOURCE: 5 HP Briggs and Stratton Engine
Take the coil off clean with sand paper then get a piece of cardboard from a cereal box or cigarette box, put the piece of cardboard in between the coil and the magnetic strip on the flywheel ''believe it or not it is the perfect gap'' 'let the magnet pull the two together'' then tighten the coil down. if still no spark get a new coil.
Posted on May 02, 2009
  • 110 Answers
SOURCE: want a repair manual for a 17 hp briggs &
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Posted on Oct 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
Posted on Jan 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: broken starter cord on briggs and stratton quantum
Remove the recoil. Sometimes depending up on model this required complete air shroud removal. Remove the parts of the old rope. Remove the rope fro the rope handle. NOTE the knot in the handle. Brun both ends of the nylon rope with a match and pinch the burned end into as small of circumference as possible. Install new rope into the starter handle and tie the knot. Pull the new rope into the handle until it seats securely.
Prewind the recoil pulley as far as you can easily wind it. Back it off (unwind) just until the rope guide and pulley knot hole are aligned. Then either c-clamp it in place with the rope knot hole aligned with the rope guide hole or have a 2nd person hold it the pretensioned spring and pulley in position. Thread the rope through the rope guide and on into the pulley knot hole. (takes some effort to get it aligned and through the knot hole!) Pull the new rope through the knot hole and tie 1 knot. Pull starter rope and fit knot into pulley knot hole. Release pulley C-clamp or have helper let go of pulley. Rope should rewind into the recoil.
Reinstall recoil / air shroud. Happy mowing!
Thanks for choosing FixYa.
Kelly
Posted on Nov 20, 2010
kel1guy2002
  • 3740 Answers
SOURCE: need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
Posted on May 10, 2011
Briggs & Stratton 16.5 Motor workshop manual
go google and type in-- workshop manual for briggs and stratton 16.5 hp motor -- if there is a pdf version , down load it
remember that the manual will cover a range of hp motors so a manual may be 14-20 hp
Nov 03, 2016 | Briggs & Stratton Measuring Tools &...
Torque spec.24 hp briggs & stratton
Try this sight, if nothing else get a manual from them,,,, I can usually find everything I want just surfing around the sight
Briggs and Stratton engine repair manuals and service guides by Outdoor...
Dec 29, 2015 | Briggs & Stratton Garden
HOW DO I GET A REPAIR MANUEL FOR A BRIGGS AND STRATTON 12 HP IC QUIET ENGINE
Try website for Briggs & Stratton. Or use Google Search for Briggs & Stratton 12 HP IC Quiet Engine Manual.
Oct 02, 2014 | Heating & Cooling
I need an engine diagram to help me put my lawnboy 10642 briggs and stratton eng ine back together
Go to partstree.com and search your model number and you will see an exploded view. Thank you for using fixya.
Aug 22, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
I need a free copy (download) of a workshop manual to suit a Briggs and Stratten 375 petrol engine?
Workshop (repair) manuals are available for ALL of the Briggs and Stratton engines. They usually cost money though. The free downloads are only for the owner's manuals. You can do a search for Briggs engine repair manuals. There are many, many of them available.
May 22, 2011 | Garden
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
