Question about Oki Electric Industry MC560 All-In-One Laser Printer
Oki b431 maintenance/cleaning page is not present
Oki b431 black image drum lock error
The drum lock error is caused by one of two items. Either the drum has seized and will not turn or the drum motor has failed and requires replacing.
Jul 06, 2017 | OKI Office Equipment & Supplies
Oki b431 service 134
It may be necessary to replace the LED head. Part number 44317201
Apr 03, 2014 | Oki Electric Industry B431dn Printer
Maintenance mode on oki mb260
I didn't see anything in the Maintenance manual but usually holding down the up and down arrow keys during power-up will get you there
Oct 08, 2013 | Oki Electric Industry MB260 A4...
Oki b431 DRUM reset
hello good afternoon, friend u can give a hint of how I resouvo the problem of drum printer oki 431dn + b, pending
Jul 05, 2012 | Oki Electric Industry B431d Printer
Help with toner reset problem on OKI B4600. After refillig cartridge, on display apears "Tonner Empty - Replace cartridge"
Go to the maintenance part of the printers program and clean the heads is the job to perform. The run a test page for alignment. It will adjust back correctly showing you have ink
Feb 26, 2011 | OKI B4600 Printer
What website do i need to get the software for the oki c5200n?
www.okidata.com
Click on Drivers & Support
On the Select Technology pull down menu, select color page printer
Under Select Model - select C5200n
Click GO
Select your Operating System from the pull-down menu and you'll be presented the drivers and instructions for the installation.
Mar 05, 2010 | OKI C5200n Laser Printer
Oki C5500 printing a yellow stripe
1) clean LED heads with Alcohol swab.
2) Check fuser rollers for dirt, smudges. Clean with swab.
3) Remove all toners/drums and check for spilled toner. Vacuum or wipe clean.
4) Check tansfer belt for marks, stray toner, creases.
4) Re-seat toner and drum cartridges.
Nov 23, 2008 | OKI C5200n Laser Printer
TEC B431-GS10 problem- Print-out in labels are only half
Various possibilities:
- The data cable on the head is not correctly inserted.
- the head is out of order.
- You are printing with a driver with a lower graphic resolution than the head resolution
Mar 31, 2008 | Toshiba TEC B-SX4 Thermal Label Printer
Yellow Lines on every print
If the optics are clean (use lint free cloth on 4 rows of black thingys underside of lid)
Then it sounds like the yellow drum needs to be replaced, when printing in word I'm guessing that you have it set to B/W prints hence no colour is engaged, no lines
Oct 17, 2007 | OKI C5100n Laser Printer
Oki Electric Industry MC560 All-In-One Laser Printer Logo
178 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Victorman
Victorman
Tony
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
