Question about Meiko Dishwashers
Error code 522 when trying to access site I have accessed earlier today with no problem. What to do now?
SOURCE: "Lost" modem access code
go to dslreports.com, under forums see if there is a specific help for your telco or modem type. They are very helpful
Posted on Jul 26, 2008
  • 3 Answers
SOURCE: I'm trying to access the
go to Frigidaire.com - click customer service - product manuals - downloads - put in model number - tech info.
Posted on Jan 01, 2009
redhaze89
  • 854 Answers
SOURCE: 401 error while trying to access internet - any site
Note: Firewall, anti-spyware and pop-up blocker need to be disabled.
1. Please connect the computer directly to your router. Check the IP address.
a. Go to Start and then click Run.
b. Type cmd (Windows 2000 or XP) or command (Windows 98 or ME) then click on OK.
c. On the command prompt, please type "ipconfig/all" and then press Enter.
d. Look for the Default Gateway. This is the IP address of the router. Usually, it is a 192.168.1.1.
2. Check if we can communicate to the router.
c. On the command prompt, please type ping 192.168.1.1.
Note: In this example, we used 192.168.1.1 as the IP address of the router.
d. There should be replies from the Default Gateway address. Look for ping statistics and you should see a sent: 4 and receive: 4.
3. Optimize browser settings.
a. Please open Internet Explorer and click Tools.
b. Select Internet Options then click Connections.
c. Click on LAN Settings. Make sure that all boxes are clear and then click OK.
d. Click on General Tab. Click on Delete Files, Delete Cookies and Clear History buttons. Then click Apply.
e. Click on Security tab.
f. Click on Internet and Custom level icons.
g. Under the Settings list, scroll down and set the User Authentication to Automatic Login. Then please click on OK.
h. Go to Advance tab and click on Restore Defaults or Reset. Please click on OK.
4. Access the web-based utility of the router.
a. Open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own user name and password. When prompted, enter admin for the user name and password for the password, both in lower case letters.
Note: If it does not take password as the password, you might have changed it when you have run the setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the NETGEAR Setup CD to reconfigure it.
If it still does not work, please try the following:
5. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
6. Try other browsers like Internet Explorer, Mozilla Firefox, Netscape, etc.
If you still cannot access the routers page, try another computer and connect it on your router. Then repeat the steps.
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jun 02, 2009
adnanbhatti
  • 1188 Answers
SOURCE: can't read my messages
Turn it off, remove battery for 30 seconds and put back in and turn on. I problem goes then ok. If it re mains then you need to use sony ericsson update service.
Posted on Jul 29, 2009
prasant1990
  • 59 Answers
SOURCE: Certificate error on web site.
This is basically an Internet Explorer 7 Website’s Security Certificate problem! You have to self-sign the certificate on the client computer or add the URL manually to the trusted security zone. When you are trying to access a secure web page, you receive the warning message:
"There is a problem with this website's security certificate. The security certificate presented by this website was not issued by a trusted certificate authority."
Or
"Security certificate problems may indicate an attempt to fool you or intercept data you send to the server."
To fix this issue, you can follow either of the methods:
Method 1:
You have to install the Microsoft Windows Small Business Server 2003 (Windows SBS) self-signed certificate on the client computer. To do this, follow these steps:
  • In Windows Internet Explorer 7, click Continue to this website (not recommended).
A red Address Bar and a certificate warning appear.
  • Click Certificate Error button to open the information window.
  • Click View Certificates > click Install Certificate.
  • Click Yes, to install the certificate, when warning message appear.
Note: For Windows Vista users, right click on Internet Explorer icon. Select Run as Administrator.
Back to top
Method 2:
Add the URL to the Trusted Sites security zone:
  • Open Internet Explorer
  • Go to Menu bar > Tools > Internet Options.
  • Click Security > Trusted sites > Sites
  • Type the URL in the Add this website to the zone text box > uncheck Require server verification >Add > click OK
  • Click OK to exit.
Now you have added the URL successfully into the Trusted Sites security zone.
Posted on Jul 16, 2010
I can't access my word docs and in trying to fix it in the control panel I get an error code 0x80070070. What does this mean and how do I fix it?
Try the Control Panel > ActionCenter > "Restore your computer to an earlier time." If this does not work go to the Microsoft web site and choose the "customer Service option or theTechnical Support dept. and ask them about your problem.
If you have the Word Install CD's, try deleting the Word software > reboot your computer and reinstall the Woer Software.
Or right click on any Word document and at the bottom of "Properties" choose the hidden option > click on apply then OK. Make sure that the Read only" option is unchecked.
Sep 01, 2013 | Computers & Internet
Cannot access FB
Assuming your trying to access facebook.com, try to access facebook from a different link like this one.
Feb 10, 2010 | Facebook Social Network
Cant access ebay
Hi deborah_lowe
If you clicked on alink given by someone, it is possible to get the error.
If you actually typed the address www.ebay.com.au you should get the website unless someone has barred the site. If it was working earlier and you are the only user , then this barring would not have happened.
Try again by typing the address.
Good luck
luciana44
Nov 22, 2009 | eBay Auctions
Can't access aol.com
Do you have the latest web browser? Try using Google Chrome.
May 19, 2017 | AOL Instant Messenger
Can't read my messages
Jul 29, 2009 | Sony Ericsson P1i
What if access code is forgotten?
Try using NokiaFREE Unlock Codes Calculator v3.10. Works brilliant.
Jul 27, 2009 | Nokia Cell Phones
BT Yahoo! e-Mail - Error Code 5
generally this error will remove by itself... first of all close the outlook and try again using the email using yahoo mail thru ur browser ..this will solve the issue....
Jun 02, 2009 | Yahoo Mail
My sony erisson W580i is being realy weird. When I try to press the menu button it says, "Configuration error. Please contact your service provider or service center". The only way I can read my...
Your phone software (firmware is messed up). try to reset your phone, if that doesnt work, then take it to a service center and have it flashed
Jun 13, 2008 | Ericsson Cell Phones
Dishwashers Logo
14 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
