Question about Plumbing
Price pfister 533-50 leaks - Plumbing
  • 6 Answers
SOURCE: price pfister sb o34-4nss leaks
Well, this is generic for fixing a Price Pfister ceramic disc valve labatory faucet. On the top of the handle, there is usually a screw cover. Pry it off. Then insert a phillips screwdriver or allen wrench, depending on model and remove. Then remove the handle. At this time, make sure the water is shut off to the faucet. You'll need a socket or wrench to remove the cartridge. On many, the size is 3/4. Loosen all the way, then pull out the cartridge and replace. They are usually between 10-30$/cartridge. Insert new cartridge, tighten (but dont overtighten or you will kill the gasket), then replace the handle and turn on water. Check for leaks.
Posted on Nov 30, 2008
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
meBNme
  • 334 Answers
SOURCE: Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Posted on Aug 24, 2009
Testimonial: "As you suggested, the faucet was under warranty and Price Pfister is sending me some parts at no costs. Hopefully, the parts will resolve the issue."
SOURCE: I have a price Pfister Marielle kitchen faucet.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Posted on Aug 28, 2009
Testimonial: "Thank you...problem solved :-) No more leaks. "
mkh5094
  • 145 Answers
SOURCE: i cant get the price pfister faucet out of kitchen...
There are several nuts on a faucet but I'm assuming you mean the plastic nuts that hold the faucet to the sink. They many times do jam up. To get them off you need to use a large flat head screw driver and a hammer and chisel them off. Chisel from the outside edge in toward the threads on two different sides.
Posted on May 23, 2010
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
Tip
Price Pfister 3pc h/c & diverter leak
If you have the Price Pfister stems they leak or will , even after replaced with a new seat washer . Try switching factory flat washer with cone shape washer and always check the brass seat in manifold for cracks, very seldom replaced very cheap pack of 10 5$ save that water we take for granted!
on Nov 06, 2010 | Price Pfister Diverter 16050A
How do I fix a leaky Price Pfister Treviso 49D faucet.
Download the instructions from the manufacturer.
Dec 28, 2014 | Price Pfister Plumbing
Price pfister chane
There should have been a new rubber seal with the purchased replacement. If not you need to contact the supplier and let them know it was not in your package.
Nov 25, 2012 | Price Pfister Plumbing
Price pfister kitchen faucet spot leaking at joint
They are wrong. There is no O-Ring at the swivel joint and it is NOT serviceable.
May 20, 2012 | Price Pfister Plumbing
My x08 shower is leaking. I replaced the mixing cartridge O-ring, and that did not fix the leak. Today I replaced the 2 piece assemble with the one piece upgrade part 974-042, but it is still leaking, so...
Replaced Price Pfister hot water cartridge but it is still leaking! I removed several times and flushed the line then replaced without solving problem. Help!
Apr 27, 2011 | Price Pfister R897EBK Brushed Nickel...
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
Price Pfister Avalon. I shut off main water to repair leak. Now faucet doesn't operate even though water is supplied to the faucet. Is there a safety/flood valve and what is the order of operations to...
No I don't think so, but if you remove the areator from the spout I'm sure you will find the screen plugged with sedenent. Rinse and replace should be fine.
Oct 24, 2009 | Price Pfister P Pfister Avalon Satin...
My price pfister tub valve leaks
Dec 26, 2008 | Price Pfister Ashfield Single Control...
Plumbing Logo
29 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
