Question about Frigidaire FAQE7011L Electric Dryers
Frigidaire FAQE7011L dryer does not spin
Dryer does not spin
  • Frigidaire Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Posted on Apr 22, 2015
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
My Frigidaire Galaxy Series Commercial Heavy Duty Dryer does not spin it heats up but doesn't spin. What would be the cause of that?
most likely cause is a broken belt.next time send the model number,i can look up your model and give part numbers.
Oct 06, 2013 | Frigidaire FDE336RE Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
Dryer spins but does not heat up lint area has all
http://www.repairclinic.com/Dryer-Troubleshooting
Mar 05, 2011 | Frigidaire Dryers
My frigidaire dryer glgr331as4 is not spinning
Hi there
i read your report. OK try this tip. Open your dryer and spin it with your hand and its spins freely with no resistance then it's your belt is bad. Try this and let me know how it goes. Ty for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Frigidaire GLGR331A Gas Dryer
High efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Mar 22, 2009 | Frigidaire FEQ332E Electric Dryer
Frigidaire FAQE7011L Electric Dryers Logo
51 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
