Question about Tascam US-144 Sound Card
Mixer not responding
I own an old computer windows 98 but it has 512 ram and it does have a good sound card. Recently, my cd writer/ cd rom would not work. Whenever I try to run a game or cd, I get a message that I need to put in the correct cd and try again. Also when I turn on my computer, it will freeze and when I do control alt delete, it shows that the mixer is not responding and sometimes ccap is not reponding. I clear up the ccap but I cant get the mixer to respond. I finally have to end task and then the computer will work okay so to speak. What is causing the mixer and ccap to not respond and how can I clear that up. Also how can I fix my cd rom and if you think I have to replace it, what is a good visual website that I can use to change the cd rom. my email is thanks, Joyce
  • 4 Answers
Re: mixer not responding
You need a better os. i would get a mac. and you need more ram 512 just won't cut it with any recording software and or hardware. also to take some strain of your computer get and external harddrive and start storing your music there. this is what i did and it worked out great for me.
Andy Kastrinelis
owner of addex recording inc.
Posted on Dec 16, 2007
  • 231 Answers
Hi Joyce, It sounds to me like you have an overlod problem, perhaps a virus, Do a scan and see if that helps, also clean or get someone to clean the heatsink and fan on your CPU. A good and simple way to do this is to remove the right side of your computer and using a very soft brush attachment on your vacumn cleaner, clean all the dust from inside the computer.
You will need to remove the heatsink to clean it.
Hope this solves your problems, regards mistyman
Posted on Nov 02, 2007
0 characters
3 Points
I have sound card genuis (sound maker 5.1) and i have windows 7 and i installed driver to sound card compatibel with windows so when make test to sound in his application or in sound in control panel the...
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 17, 2011 | Genius Soundmaker Value 5.1
No output
Make sure you have your speakers connected to the main output. Also, in the "Universal Control" "Mixer" window, make sure that at least one of the mixes are assigner to "Mo", which stands for main output.
Feb 03, 2010 | PreSonus FIRESTUDIO Sound Card
I have no sound at all..everything tells me that all is good and enabled, could it be my card is caput....
Can you please tell me if when you turn on the computer if you are getting sound windows sound. then it is some settings in the computer check if mute is not checked or check in device manager if the correct sound drivers are installed.
Jan 03, 2010 | Creative Labs SB0100 Sound Card
Need sound driver for sony vaio model PCG-Z1RGP
Not sure what operating system you are using, but a quick Google search came up with this:
Sony does not offer audio drivers for this computer.
However, they do offer this:
Err Msg: Cannot play back the audio stream: no audio hardware is available, or the hardware is not responding.
Please check if there is any exclamation mark (!) displayed in Sound, video and game controllers under Device Manager. If there is any exclamation mark (!) in the Sound Driver Devices, please reinstall the sound driver with the steps below:
1. Start up the computer.
2. Insert the last disc of the set of Recovery CD-ROM into the CD-ROM/DVD-ROM drive.
3. Double-click My Computer and double-click the CD-ROM/DVD-ROM drive
4. Double-click the VAIO folder and search for the Audio folder in the Device folder.
5. Double-click the Audio folder and double-click Setup.exe
6. Follow the on-screen instructions to install the Sound Driver.
7. After the installation is completed, remove the Recovery CD-ROM from the drive and restart the computer.
* If the problem persists after reinstallation of the Sound Driver, please follow the steps below to check if there is any latest device driver upgrades:
In the Downloads section, please select Notebook and proceed with the steps below:
1. Move the cursor to the relevant Notebook Series and click the model of the VAIO computer.
2. Locate any latest Sound drivers and proceed as per instructions on the screen.
* If the problem persists after performing the device driver upgrade, please contact the local Sony VAIO Helpdesk. For more information on how to contact your local Sony VAIO Helpdesk, please refer to either Customer Service Guide or Warranty Card that comes with the computer, or visit the Support Network of the VAIO website.
Jun 14, 2009 | Audio Cards
I'm looking for a driver to my sound card
how can i download PCI Device, video and network controller drivers
Mar 30, 2009 | Philips Audio Cards
I can't find the correct audio card driver for win 3.1
CM18738/C3DX Pci Audio Dev (sound video vision
Mar 30, 2009 | Packard Bell (030069) Sound Card
DVD is not recognized - dell laptop
i think ur local disk d is dvd writer driver.
this problem is check the dvd driver.
otherwise go and replace the dvd driver. comfirm ur dvd writer problem. other wise disc problem. please check your dvd driver.
Aug 16, 2008 | Lexicon Omega Desktop Recording Studio...
Sound Card Compatbilty
it has to be at least Pentium® III or AMD-K6® III processor 500MHz or faster; Windows 2000 or XP; 64MB RAM; 1 free PCI 2.1-compatible PCI slot and 1 other free slot; CD-ROM or DVD-ROM drive; 800 x 600 screen resolution with 16-bit color
Jul 17, 2008 | Dynex DX-SC5.1 Sound Card
Hi Diviola, you have no choice but to buy a CD-ROM drive. They are not as expensive as you might think. You're windows CD can format the hard drive in you're computer before installing windows. Some people can use a USB memory stick but in order to copy the windows CD software to the memory stick you'll still need a CD-ROM drive. A 2GB or 1GB memory stick will cost as much or more than a CD-ROM drive. Please click on the link to see some prices for a standard CD-ROM drive.
& here.
The link above is a CD-ROM drive & can also make CD-RW's (RW stands for re-write).
You can replace you're CD-ROM drive you're self. Just do not disconnect the cables from you're old CD-ROM drive untill you have the new drive. Connect the cables to the new drive (one at a time) as you disconnect them from the old CD-ROM drive.
Double check that the cables are tightly connected before you power up the PC. Load you're windows CD into the new CD-ROM drive & when you start you're PC up windows will start to load.
When you receive the new CD-ROM drive & if you need help connecting & running anything. You can come back here & ask questions. I'll help you through this.
May 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
NO Sound at all
hi u r audio drivers are not installed
so plz follow insructions
mycomputers - rihtclik n u get manage
device manager
find audio drivers n update it
i think it's will be ???(question mark) symbol
update it frm cd rom,
put mother board cd into cd rom.
ur's kishore chowdary.
May 04, 2008 | Intel Premier Resources 4-Channel 32-Bit...
Tascam US-144 Sound Card Logo
151 people viewed this question
Top Tascam Audio Cards Experts
Brian Sullivan
Brian Sullivan
Ben Armstrong
Are you a Tascam Audio Card Expert? Answer questions, earn points and help others
