Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
SEAGATE 9ZC2A8-500 How to in win 8 - Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
How do I get operating instructions for Seagate STBX1000101
Windows 8/8.1 does not use the traditional Windows backup utililty that was found in earlier Windows releases. Instead, a tool is built in called File History. There are several ways to get to this, here's one of the ways:
Tap your Windows key to bring up the Start screen. Start typing the words File History and click on File History Settings.
Here's a link to a page on Microsoft's site to help you with this process:
http://windows.microsoft.com/en-us/windows-8/set-drive-file-history
Oct 02, 2014 | Seagate Expansion 1 TB USB 3.0 Portable...
I have this seagate momentus hard drive, i had windows home buitin and then i upgraded to 8, after that i formatted my reserved and recovery parttion as i wanted a clean intallation and now i cant see my...
First off....8 is not an upgrade, Win 10 is an upgrade.
Forget looking for any data from your old hard drive as it has been written over and you cannot retrieve it any longer. Just obtain a copy of Windows Ten or pay for a new updated disc. Let Windows format the hard drive and install itself for you.
Feb 08, 2018 | Seagate Momentus 5400.6 (ST9250315AS) 250...
ASUS M3A78-EM stopped seeing second drive
update your drivers and check the cables out as well
Jan 01, 2013 | ASUS M3A78-EM Motherboard
Will not recognize extra sata hard drive with win 7 lenovo running win 8
need to go to bios and do change settings. ive never done it with two hdd's i just partition and dual boot. os's were win 7 64 bit and win 8 64 bit.
Dec 14, 2012 | Seagate FreeAgent Computers & Internet
Purchased my Seagate June 6, 2008 and have used it just a few times with my Win XP. I recently bought a new PC with Win 7 onboard (naturally). Now I want to transfer (copy) my music and photo files from...
Certainly, any files that you write using Windows XP will be able to be read with Windows 7.
I'm not familiar with the CEEDO program -- did the author update it for Windows 7 ?
Dec 26, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I can't eject my portable hardisk on my win 7
There is a bug in windows 7 operating system.
Like Vista. Usb 5v Power not stop in win 7 upgrade operating system
with windows 8.
Nov 23, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have a Seagate ST3200822AS 200 GB Hard Drive(windows XP).I want to use this as external but I don't want it to mix with HD on new computer(windows 7). How do I keep them separate and run one or the other...
Is the Seagate ST3200822AS an External Drive ( like USB connectivity ) or actual Hard Drive ? Even if it is Internal Hard Drive, You can make connect it to Win 7 and still keep it as Seperate Drive.
Connect the Hard Drive to Win 7 PC and Make it Slave ( partition ) by changing the Jumper on the Hard Drive ( jumper is a small pin or a lock that makes a Hard Drive Primary or Slave.
Once you connect the HD to Win 7, you will find new Drives Created in Win 7, this way you will differentiate between the Win 7 Drives and XP Drives
This link will how you the jumper position : Remove the jumper from slot 1 and put it in slot 2
http://www.google.com.sg/imglanding?q=changing%20jumper%20on%20Hard%20drive&imgurl=http://www.mysuperpc.com/build_your_own_computer/sata_hard_drive_connectors_jumpers_cr.jpg&imgrefurl=http://www.mysuperpc.com/build_your_own_computer/pc_install_sata_hard_drive.shtml&usg=__iTyJjkCN501Kstme6LZ42u0Q3ZU=&h=538&w=600&sz=95&hl=en&um=1&itbs=1&tbnid=2EXt5zyA0OXYxM:&tbnh=121&tbnw=135&prev=/images%3Fq%3Dchanging%2Bjumper%2Bon%2BHard%2Bdrive%26um%3D1%26hl%3Den%26sa%3DN%26tbs%3Disch:1&um=1&sa=N&tbs=isch:1&start=8#tbnid=t42Gq31Rw32OCM&start=13
Jun 30, 2010 | Seagate ST3200822AS 200 GB Hard Drive
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Win 98
You would need two set of driver:
  • motherboard USB drivers;
  • mass storage driver from Seagate for Win98.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Seagate 320GB
It could be that it's formatted as NTFS, which Win 98 probably can't recognise. Problem is FAT 32 can't deal with drives over about 80 GB. There may be software patch out there to allow NTFS on Win 98, or (only solution I have used), you could format it as several partitions, including at least one FAT32 for your machine to see.
Sep 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
