Question about Honeywell 3800g Barcode Scanner PN 3800G14SERKIT3E Handheld Barcode Scanner
Honeywell 3800g driver - Honeywell 3800g Barcode Scanner PN 3800G14SERKIT3E Handheld Barcode Scanner
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
Where I found the USB driver for a 4410 HD scanner?
This is actually a Honeywell product now. The drivers should be part of the Quickview, Visual Menu software packages. Those are a free download. You need to go to honeywell.com and either search for your model to find the page or go to products scanning and mobility
Installing those should get you running.
Sep 02, 2011 | HHP ImageTeam 4410HD Handheld
Need installasion instructions as well as program
Hi
Click hear to find the manual read the manual and install the your HoneyWell 3800G
Jun 08, 2011 | Honeywell (formerly Hand Held ProductsHHP)...
My 3800g barcode scanner puts a prefix of ~% before the UPC number. I'm sure the answer is somewhere in the 156 page manual, but to a non-technical guy like me the manual may as well be written in...
Hi
If you have the user guide then go to the page 48(4.3) there all option available, To clear the perfix and suffix, other wise download the user guide to Click hear
May 26, 2011 | Honeywell 3800g Barcode Scanner PN...
My mac is not recognizing barcode reader honeywell MS5145
The scanner may need drivers, check for the brand name and go to their website to find the required drivers (if any.) If you already have drivers installed, try other USB ports.
May 04, 2011 | Honeywell MS5145 Eclipse with Codegate...
FocusBT 1633 scanner will not scan. Windows XP says USB device is unrecognized. Owners manual indicates there should be an installation CD included for proper driver installation but Honeywell support...
win xp is a far outdated os and may not be compatible with the scanner
click on scanner properties and then the compatibility tab and see that the small square is ticked and then high light win xp as the OS
If there is no win xp , it will not work
if all is there then get the honeywell web site open and down load the driver for that scanner
Jul 30, 2017 | Metrologic Instruments...
Hi, I am trying to install the drivers for my HandHeld 3800G Linear Imager (barcode scanner), but keep getting the following error: "Cannot Install this Hardware There was a problem installing...
you may have to delete the file or uninstall-then reinstall..if this does not work you may have to go to the honeywell site and reload the drivers again as you may have lost a thread during the initial download ...happens more than you think...good luck
May 19, 2017 | Honeywell (formerly Hand Held ProductsHHP)...
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
Honeywell 3800g Barcode Scanner  PN 3800G14SERKIT3E Handheld Barcode Scanner Logo
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
