Question about Frigidaire Puresource Ultra Filter Ultrawf Ice Water
Filter loading problem
Filter won't engage and lock. keeps pushing back out
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Seat back won't stay up
Probably has a broken or jammed lock When you position the seat try pulling/pushing the handle instead of relying on the spring to engage the lock. If the seat frame is broken remove it for repair or replace with another seat back
Feb 22, 2013 | 1998 Toyota Corolla
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loader washing machine won't start
You will need to replace the door lock. Here is the part to order.
To replace the lock, remove the band securing the boot to the front panel and fold back the door boot. Now you can access and replace the lock. Let me know if you should need further help.
Nov 05, 2012 | Washing Machines
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Crosley washer CFW7500KRO - Door lock won't stay engaged
Unfortunately I had the same problem and it ended up being the control board not sensing the switch being closed. Had to replace the control board
Sep 06, 2012 | Washing Machines
AFTER I PUT GAS THE CAR WON'T STAR UNTILL I PUSH THE GAS PEDAL AND I HAVE TO KEEP PUSHING SO THAT I WONT SHUT OFF
If you have this problem only when you fill your tank I would check the fuel filter first. The fuel pump will also give you problems after filling the tank due to the extra load.
Feb 09, 2012 | 2005 Mazda 3 2.0
Whirlpool self clean GGP84803 door won't lock when initialized.It is clicking and diplays locked but I can still open door?
If the lock will not engage and keeps locking and unlocking then turn the power off, slide the stove out to obtain access to its back. Remove the 3 screws from back cover and you will see the locking motor and a switch with a lever that rests on the locking rod. This lever has lost its firmness and does not engage the switch to tell the motor it is locked. Simply take a pair of pliers and bend the lever down to put more load on the lever. Now when the rod turns it will fully engage the switch which will tell the motor that the door is locked. Test your setting to make sure you have it adjusted right and then re-install your cover and push your stove back into position and enjoy your day. Takes 10 to 15 minutes and is cheaper than calling a service tech. Remember to turn the power off when working on the back of the stove through testing and such. No need to get hurt.
Jul 02, 2010 | Whirlpool Ovens
Frigidaire Puresource Ultra Filter Ultrawf Ice Water Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
