Question about Magic Chef Refrigerators
Magic Chef refridgerator with small built in freezer model#MCBR 980W. Defrosting instructions unclear; red button suppose to be pushed in for defrosting the small freezer, How is it suppose to actually work? If depressed and you leave it to do it's own thing, It turns its self off before the ice is melted off the freezer and it all just refreezes again. Do you have to turn off the temperature gauge of the fridge also? Do you need to leave all doors open/closed when defrosting?? Any help would be much appreciated , Thank you. (Heidi Smith; ooosmith@comcast.net)
I just defrosted my cooler and looked at the manual. It says that you should do it when the ice is only a 1/4 inch thick. Then it will do it without any effort. Well of course i waited till it was about 1 1/2 inches thick. The defrost button does help though. i pushed it and waited 3 hours and that loosened up the ice around the box. Then used an ice pick, flat head skrew driver, and a painters 5 in 1 tool. I cleaned the inside of the freezer fairly eaisly and let the rest of the defrost process clean the top and the sides of the box which i couldn't reach.
Posted on Apr 16, 2010
I have a magic chef fridge model MCBR1000W and the freezer turns off and when I push a red button in the back it clicks and turns on again. What is the problem with it.
The red button is a circuit breaker and you are resetting it by pushing the button. Some circuit breakers of this type become unreliable and open the circuit randomly, often at some inconvenient time. Still, there could be a valid reason the breaker is popping.
May 22, 2018 | Magic Chef Refrigerators
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
I have a small magic chef fridge that just stopped working. Can seem to get the motor going at all - if just defrosted by itself. Inside is a dial and a red button - we've clicked that a few times to try...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Magic Chef MCBR445S1 Stainless Steel...
Hi i have a magic chef model # mcbr 1010b it was working great unti i left the door ajar overnight and now it gets very cold in freezer @ 0 degreeze and refrig part stays around 50 and seems like it will...
Since you left door open I think the evaporator is frozen up .Just shut it off for a while and let everything defrost then turn it back on and you should be fine
Jan 05, 2018 | Magic Chef CTB1722 Top Freezer...
Magic Chef Model MCBR 1020w refrigerator making a clicking noise.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 17, 2010 | Magic Chef CTB1502AR Top Freezer...
The bottom part doesn't cool things. only gets 66/67 degrees Fahrenheit.
Usually when this happens it is either a evaporator fan or a defrost problem. Check that the fan in the back of the freezer is running. Or if there is frost on the back of the freezer. Frost indicates a defrosting problem.
Jun 27, 2010 | Magic Chef CTB1821AR Top Freezer...
Our model is MCBR 415S. The top freezer acts as
You most likely have a bad thermostat control or a bad defrost timer.
Locate the defrost timer, probably inside the temp control panel.Defrost cycles should last 30 minutes then resume freezing.
Manually turn the timer control a 1/4 turn and see if it starts.
If so, replace the defrost control.
It could also be a bad temp control.
If the timer adjustment does not start the fridge. Tap the temp control. It may have stuck contacts.
Mar 10, 2009 | Magic Chef Refrigerators
Our Magic Chef fridge model # MCBR1000W does not seem to be keeping the fridge part cool enough, but still keeps the items in the freezer section frozen. The compressor is working, so not sure why this is...
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Magic Chef Refrigerators
Open Questions:
Refrigerators Logo
984 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
