Question about Bosch B26FT70SNS
How to reset a filter display on a bosch refrigerator
From our bosch manual: press and hold the light/filter button for 3 seconds. the water symbol is reset. the symbol stops flashing. the new filter cartridge is activated.
Posted on Jul 28, 2014
Reset Water Filter Button; Stays Red after changing filter on Frigidaire Refrigerator/SideBySide LGUS2642L
Thank you for your inquiry, John Sodt!
From what you have described your Frigidaire refrigerator's filter display is not changing back to green after the filter has been changed. This could be a miscommunication within the control panel and to clear out any miscommunications I would suggest performing a reset on your refrigerator. The best way to reset your refrigerator is to unplug the power cord for roughly ten minutes. If that does not help your issue you may want to speak with a professional technician. Good luck. -Matt
Feb 11, 2015 | Frigidaire Refrigerators
Why won't the water filter light up on the display panel?
The lamp should only be lit when the filter is due for replacement.
Jan 08, 2015 | Bosch B22CS50SNS Side by Side Refrigerator
How do I change temperature display on Bosch refrigerator from celsius to fahrenheit?
Hold down the "super/quick ice" and "options" buttons together for 5 seconds.
Depending on the previous setting, the display switches to the other temperature unit.
I hope this helps.
May 10, 2014 | Bosch Refrigerators
Cannot reset the filter light
Hi David, this is AP.
I understand you are having trouble resetting the water filter light on your Frigidaire refrigerator. On this model, FGUB2642L, I would start by pressing and holding the water filter button located at the top of the display panel for 3 seconds if you have not already. If that option does not work I would recommend using the default settings button. Hold down on the button to reset all refrigerator settings. If that still does not rest the light I would suggest cutting power to the refrigerator for a few minutes to reset the display. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thanks,
Mar 21, 2014 | Frigidaire FGUB2642L
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
When our GE Profile refrigerator displays "reset filter" in the display, does that mean replace the filter?
There is a built in timer to turn on, usually after 6 months, to remind you to change the filter. Many people go longer before replacing the filter, depending on water conditions and usage. (if refrig is supplied by an RO system, filter is not needed) If you push and hold the reset for at least 3 seconds, the timer (and light) will re-set.
Mar 06, 2011 | Refrigerators
The control panel does not seem to work on the door. None of the switches work, ice,water, options, alarm. The change filter sign on the main display is highlighted. I tried turning the refrigerator...
Yes the filter needs to be changed after the change filter light is indicated.After changing the filter the unit has to be reseted.The reset procedure is as follows:--- press and hold the Water Filter Reset button for 5 seconds. Newer models: press the Options button until "filter change" is selected, press selection buttons +/- until the "filter change" display goes out.-------------------- Thank you.
Jan 31, 2011 | Siemens KA62DV50GB Side by Side...
Asterisk symbol Bosch Refrigerator B20CS50SNS
It means it is time to change the water filter. You can hold the button down for a while and it will reset whether you change the filter or not.
Mar 14, 2009 | Bosch Evolution 500 B20CS50SNS
Bosch B26FT70SNS Logo
664 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
