Question about Maytag MSD2656G Side by Side Refrigerator
Refrigerator leaking water on floor under it!
I have a whirlpool refrigerator side by side 6 years old and it hs started leaking water under it onto the floor under the freezer side. I can't tell where it is coming from. I have checked the drip pan no problems there and all of the hoses and fittings that go to the ice maker and water dispenser are good. It is leaking a fair amount of water but I can't tell where it is coming from. Do you have any suggestions?
  • Maytag Master
  • 4,655 Answers
The leak is most likely coming from the defrost tray below the evaporator coils. A piece of ice or something is preventing the water from draining to the pan below your refrigerator. Unplug and remove the back panel inside the freezer. Any blockage from that tray will cause the water to pool out into the freezer or fresh food section. Thanks, Sea Breeze
Posted on Jun 18, 2009
    Scholar:
    New Friend:
  • 142 Answers
I would recommend that you examine the drain hole and physically remove all visible debris. Pour a mixture made from a teaspoon of baking soda dissolved a 1/2 cup of warm water into the hole. Baking soda is great because it helps to break down the cell walls of plant matter (like any algae living in the drain) and removes smells, too.
Then use a long piece of pipe cleaner to push any remaining debris down into the evaporation tray underneath the refrigerator.
Posted on Jan 02, 2015
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
How do I remove the drip pan from under the freezer? It's full and leaking onto the floor?
There should be a decorative kick panel underneath that will snap out revealing the drip pan which will then slide forward and out to pour the water off.
Nov 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking onto the floor directly under the freezer of my side by side g.e. refrigerator. Water is frozen in bottom of freezer floor. Is this a costly fix? Refrigerator is 10 years old.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water Leaking all over from Whirlpool Gold Refrigerator
I think that the seals are ruined when the seals are ruined the water will leak outside and inside beacause all of the heat from outside will gather together and will melt the ice and will make the moisture act up and boost the process of it turning to gas matter into liquid matter.
Apr 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag MSD2656G Side by Side Refrigerator Logo
659 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
