Question about Fender 2232200000 Blues Deluxe Reissue Guitar Amp
How to remove speaker in blues deluxe reissue
2 Suggested Answers
  • 5603 Answers
SOURCE: Fender blues deluxe reissue is making a popping
Try tapping the tubes (especially the small ones) lightly with a regular wood pencil and see if you can detect noise. Also verify your guitar AND cable are not the source of the noise by using them on another amp. Verify that popping exists witout guitar cable being plugged in.
Also this is the season for static electricity. Shuffling shoes on rug may create pops due to discharges. Spray rug with Staticide if this is the case.
Posted on Mar 14, 2011
I replaced Can I change the tubes on my fender blues deluxe reissue from 6l6 to 6v6 power tubes
An internal component has failed. Without it in front of me for testing I cannot say which. You need to takje it to the repair shop.
Jan 28, 2016 | Fender BLUES-DELUXE-REISSUE Tube Guitar...
Is this a 61 Reissue? 121100384Serial number
Not sure to exact model guitar you are referring to
Fender, Gibson, etc...?
I do know that it looks more like a reissue #
if it was Not a reissue it would have a lower number Vintage Guitars Info Fender collecting vintage guitars fender stratocaster... Vintage Guitars Info Gibson collecting vintage gibson guitars
Mar 25, 2015 | Gibson Custom Historic Reissue SG Guitar...
I have a Blues Deluxe it has started making a in and out sound similar to higher pitch hum but in and out at a constant pace
check out your tubes....it sounds like one is working its way out of its socket or you have a microphonic tube...may be time to replace them and have the amp serviced while you are at it. ...Does one tube have a whitish look? inspect them/.....are there any cracks? while it is on...tap them with a lead pencil...something NOT metal...does it make a loud noise? These are all indicators there is something going on with your tubes..Good luck
Feb 26, 2015 | Fender 2232200000 Blues Deluxe Reissue...
Why is my Fender Blues Deluxe Amp making a crackling sound without an instrument even plugged into it and when I do plug in, it quiets when I touch any place on the guitar?
You probably need a new input jack on the amplifier. When they get loose the connecting wires can crackle, but plugging a guitar in stabilizes them (no more crackle).
Feb 11, 2015 | Fender Blues Deluxe Reissue Tweed Combo...
Is there any way to use a heil talkbox with a fender '65 deluxe reverb reissue?
No - you use these with a microphone. Plug you guitar into the Heil, put the tube in your moth and sing into a mic while playing. You CAN plug the microphone into the fender amp, but a PA system is better
Oct 15, 2013 | Dunlop Ht1 Heil Talk Box
Input not working
Need a bit more info before I would have a good idea of whats the cause. I t may be a jack, the preamp, or one of the opamp chips as examples (just to start) One of the first thing is to turn it on let it warm and simply see if all the tubes are lit. Next is to try both input channels. Plug something into the jack and play with controls. Then switch jacks and repeat. If you get no sound that means we are looking at something in the board or output end (well most likely anyway) What we are trying to do is narrow it down to a section of the board or tube or ******.
When these are working they are one of the best sounding amps. Unfortunately there are a few years where the build quality is less than perfect. My friend plays blues and I got so tired of fixing this beat I ended up taking all the parts off and using military and aerospace grade parts. Sounded better and it hasn't dared break again ;-] If this is a 90's one best advice is if you are going to a gig have a spare.
Sep 29, 2011 | Fender 2232200000 Blues Deluxe Reissue...
Fender blues deluxe reissue is making a popping sound
Mar 13, 2011 | Fender 2232200000 Blues Deluxe Reissue...
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Unable to activate reverb and drive channel with either cabinet switches or footswitch. Brand new out of the box so it must be something I am doing.
Make sure you have the CORRECT foot switch pedal. Try unplugging the pedal and then try the cabinet switches to see if they work. The pedal for this one has a different circuit than some. I have the schematic and we can do further testing.
Dec 28, 2010 | Fender 2232200000 Blues Deluxe Reissue...
The small opening that the speaker wire plugs into has fallen back into the speaker. I can't get the plastic cover off the speaker to put it back in place.
The grill on these is hard rto dislodge.
There are a couple little screws to remove. Then you have to be fairly aggressive to get the lip of the screen dislodged. start at the center of the SHORT edges and pry under in the middle. The edge of the screen goes into a grove with rubber on the side.
Note, some of these MAY have adequate access by removing the socket where the unit can set on a pole.
You MAY be able to manuever the plug and possibly lockwaser into place. Use a stiff wire with a small bent hook to capture the plug and pull i back through.
May 17, 2010 | Fender Passport Deluxe 500watt Sound...
Fender 2232200000 Blues Deluxe Reissue Guitar Amp Logo
18 people viewed this question
Top Fender Music Experts
Michial Gueffroy
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
