Insignia ns lcd15
TV turns on and off with remote,but is locked on one channel with volume all the way up. I can't change the channel or the volume with either the remote or the controls on the TV itself.
SOURCE: tv is locked
hi guys got same tv same prob......finally after hours of frustration found a solution.
steps:
  • Turn on tv
  • Press and hold the menu button (you will hold this through the next few steps till the menu comes up)
  • turn the tv off using the silver button on the back of the tv
  • push the button back in on the back of the tv
  • tv should come on and bring up the menu
  • using the channel and volume get to the menu with the v-chip controls there should be a reset menu button change it to on.
  • turn off tv using power button on front of tv.
  • turn it back on and problem should be solved
Posted on Dec 04, 2007
MNfisherman
  • 11896 Answers
SOURCE: TV won't change channels or adjust volume
Do you have a universal remote? If the batteries are taken out for a little period of time, the remote will loose the codes and they will have to be reset. You can find the codes by google universal remote codes.
If you have a factory remote that came with the television, than it may be faulty or the sensor on remote or tv may need to be cleaned.
Posted on Mar 11, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
Posted on May 10, 2009
SOURCE: i need the att uverse remote control codes for and
hi! i have a couple of codes for your insignia tv, you could try them 0103 0189 0217 0135 0133 0116 0167 0456 0029 hope it would help. goodluck!!!
Posted on Jun 03, 2010
Insignia lcd won't change channels
on the off chance read the owner manual as the set may have a feature that locks the keyboard and the remote out
Aug 27, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Can I change the font size for closed captioning on model no NS-LCD15-09 TV
To change the text size of close caption, you have to enter its service mode options. For more details, check this link by search to your TV model number
Feb 11, 2012 | Insignia Televison & Video
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
Cant program a channel into insignia tv dont have remote only dish remote
It's my understanding that you're trying to get your DISH remote programmed to your TV, rachellebria. The following are the steps you can take to get that accomplished:
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Hope that helps!
Nov 28, 2010 | Insignia NS-13CTV
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
URC 4220 will not operate 14" Insignia TV (NS-14FTV)
need code to set my urc4220 universal control for my zenith tv
Mar 22, 2009 | One For All URC4220 Remote Control
Insignia remote will not turn on or off the TV
Setting the Remote to control power on your TV is really easy. You just hold down the TV power button and you start pushing UP on the channel button.
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
