Question about Canon EOS Rebel XSi Digital Camera
I cannot format a new sd card
I put a brand new card in my camera and it said cannot format change card
    Sergeant:
  • Canon Expert
  • 454 Answers
You may have the card locked Find the small switch on the card to ensure it is not in the lock position.
Posted on Sep 02, 2016
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
old marine
  • 1978 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
t00nz
  • 4738 Answers
SOURCE: Can't unlock 4gb sd memory card
There's a tiny slide switch on the side of the card. Slide it to the other position and try again.
But one thing I've noticed is that you mention that the card is 4GB. As such, it's likely that this card is an SDHC card. There is also a possibility that your A540 camera is not recognizing the card as the SDHC format came out well after the A540 was designed.
If you're still having problems with your 4GB card, recommend trying again with a standard SD card (2GB or less). 2GB standard SD cards are very inexpensive, and can be found on Amazon for about $7 with free shipping.
And hang onto the 4GB card. It will come in handy again someday.
Posted on May 27, 2009
  • 68 Answers
SOURCE: How to format an SD card on a Canon SD600 camera
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb.  Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb.  Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
Posted on Feb 22, 2010
angelo_mlc
  • 1035 Answers
SOURCE: SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Posted on Apr 07, 2010
Brand New Canon Rebel T3i not reading SD cards.
It looks like the camera is faulty.
Take it back to the shop for a warranty repair or replacement.
Apr 20, 2013 | Canon EOS 600D Rebel T3i Digital Camera
My SD card will not format
Get an SD card. Your 8GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work with your camera. You need to use an SD card, 2GB and smaller.
Jul 19, 2012 | Kodak EasyShare CX7530 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
New 2 GB Memory cards say cards full when installed
The SD card may have to be reformated. You should do this in the camera you want to use the SD card with. Do not format the card with your computer.
In you manual or on the menu of your camera there is a "Format" procedure. follow that and your camera will work again (REMEMBER) if you have images on the SD card down load them before you format the card.
Once you down load the images from your camera you should reformat the card to clear it in order to shoot more images.
Mar 20, 2009 | Kodak EasyShare C330 Digital Camera
Card Error
please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-2300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-2 Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
