My RES radio CD player does not play, and does not come out.
Res radio with CD player, Dodge Grand Caravan SE Starts and stops, and then won't play flips to FM radio and back to CD.
golu_fixya
  • 213 Answers
SOURCE: LCD says HOLD
format it only
Posted on Jun 14, 2008
SOURCE: 2005 dodge caravan rbq am-fm radio w/6 disc cd changer
Contacted local dodge dealer about my in dash 6-disc changer problem. Chrysler seems to have an "exchange" program. They will remove your existing radio, install a "factory reconditioned" unit and send yours in to be repaired and sold to someone else. The dealer told me that my CD's would EVENTUALLY be returned to me from Chrysler. The cost I was given was $265 plus sales tax for the exchange unit, and the labor to remove and reinstall. He said about a half hour labor. Compare this to the $604 for a factory new unit. Hope this helps everyone with this problem. I was told by the Service advisor that it is common for this problem.
Posted on Jan 30, 2009
SOURCE: 2005 Dodge Grand Caravan radio and power outlet stopped working
check your rear tail light in the rear window, usually if this goes so does the outlet
Posted on Feb 11, 2009
thepartspros
  • 36 Answers
SOURCE: No FM reception on factory 1996 dodge grand caravan radio
replace the attenna if that does not work the radio is the problem
Posted on Jul 16, 2009
SOURCE: NEEED FUSE FUSE BOX LAYOUT FOR 2003 DODGE GRAND CARAVAN
You can get free owners manuals online at:
http://www.edmunds.com/ownership/howto/articles/120189/article.html
or just type "owners manuals" in your search.
Here is a post I found that worked for my 2005 caravan.
For a 2001 Dodge Caravan: The owner's manual is vague, only stating that all fuses are under the hood in the fuse box, no diagrams. Once you have removed the fusebox cover, the diagrams for what each fuse does is provided under the lid. UNCLEARLY marked is the radio fuse, a 20amp fuse located 2nd row from top to the right of the accessory relay. It is marked: RDO/IP IGN.
Jake
Posted on Sep 19, 2009
My cd player in my 08 dodge grand caravan won't continue to play the songs after I turn the van off, when I start it up again, the cd starts over from the beginning. ....how do I fix this?
Sounds like a cd player that is an after market.... just hook up the power wire to a battery always live fuse... ie a power connection that isn't interrupted by the ignition. however be sure that the radio doesn't have an anti theft system or as soon as the Power wire is disconnected the radio will have to be reset.... there should be a wiring diagram on the top of the radio or on the bk... look for the wire marked memory and hook the power wire up to the same spot on the fuse box.... the memory wire runs the clock, channel selection and anything else that needs power at all times, even when the ignition is off and the keys are removed so it will be a great spot to hook your power wire to also... just splice into that wire with a splicer but, if your system is a high powered system run an independent wire from the battery through the fire wall so you do not blw a fuse or cause a fire.
Feb 26, 2015 | 2008 Dodge Grand Caravan
The CD and cassette players do not work.
pull the radio assembly out check to make sure that all your wiring is connected to the radio securly
Feb 10, 2013 | 2006 Dodge Grand Caravan
My 2002 Dodge Ram cd Player doesnt work. My radio will work but my cd player wont. I put a cd in it and it says track 00/00 and does nothing, What should I do?
The player is shot! I have a 2002 Grand Caravan SE that had a similar situation with it when I bought it. You're better off putting in an after-market player.
Apr 29, 2012 | Cars & Trucks
The radio in my dodge grand caravan 2007 has quit
Your best bet might be to go to www.car-parts.com and find a salvage yard in your area with a used radio.
Dec 23, 2009 | 2007 Dodge Grand Caravan SXT Minivan
Feb 07, 2009 | 2000 Dodge Caravan
42 people viewed this question
 Grubhead
Grubhead
