My CD player does not play, and does not come out.
RES radio does not operate properly, it starts and stops and then won't eject.
emissionwiz
  • 80339 Answers
SOURCE: 6 disk cd player error
This is a part failure in the mechanism that loads and ejects the disk, there are no repair manuals avail to either the tech or the consumer, the only place that the factory gives this info and parts to are factory authorized repair stations, bottom line you must pull the deck and contact a Ford dealer in your area for location of the nearest factory repair station. I was dealer tech for 20 years and that is how it is done.
Posted on Nov 21, 2008
SOURCE: 2005 dodge ram cd player won't eject cd
the dealer told me not to use burned cds to long in the cd player. the cds are a little thiker then a regular cd. i had to not use the cd player for a couple of days. once the cd cooled down it cam back out and i havent had a problem since. Solution dont let burned cds get to hot
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: CD stuck in CD Player - 1998 Mazda Protege
It might be a Bose system. I usually remove stuck CD's by grasping the edge with a pair of tweezers and pulling slowly, there will be some resistance. Try to reset first by removing the fuse for about 30 seconds and after it powers up again (don't turn it on yet) push the eject button.
Posted on Apr 20, 2009
  • 47 Answers
SOURCE: 2002 Honda CRV factory radio - CD Plays but will not eject
mustangs do the same thing, on those if you swipe a credit card UNDER the cd while its ejecting it will come out, hope that helps.....
Posted on Jun 29, 2009
  • 11 Answers
SOURCE: Single CD Player has a CD stuck..the CD will
while pressing eject,slip another disc in the slot 1/4''. wait a couple seconds till you feel it being pushed out by the original cd. do not put the original cd back in till you have cheched for scratches or a warped disc. hope this helps
Posted on Aug 08, 2009
CD Player keeps ejecting the CD
Either Cd is problematic or lens inside of cd player is covered with dust. There is no way of properly cleaning it unless you remove the cd player out and disassemble.
You may try cd cleaner kits but ususally they cant help.
Nov 25, 2011 | Cars & Trucks
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
Turntable will power up, all the lights come on,reads the cd but does not play. unit has to be turned off then on to eject the disc ? (hope this helps) Any ideas?
One of the buttons has got stuck, so when you press the button you want to, its not getting the message to start / stop playing. This is also why the eject won't work. Either a new button, or replacement board would make it happen for you :)
Jun 24, 2011 | Pioneer CDJ-1000 CD Player
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
Radio stopped working properly! Pontiac G6, 2006, 6 cylinder.
The CD load/unload mechanism appears to be malfunctioning.You have to take the radio out and see if you can manually remove the disc or pick up a used radio from the scrap yard
Dec 24, 2017 | 2006 Pontiac G6
Trouble Ejecting CD. CD not playing
One thing have you tried to pull the CD out?
Dec 09, 2009 | 2001 Dodge Caravan
I cannot get the CD player to eject the CD. the radio is a standard AM/FM radio with a CD player in a 2005 Ford explorer XLT. after pushing the eject button the radio screen blinks ''EJ err''. The cd...
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
Sep 30, 2009 | 2005 Ford Explorer
CD player clicks and won't eject cd
We have this problem all the time. Sadly, replacing the radio is the only answer.
Aug 30, 2009 | 2005 Chevrolet Equinox
 Grubhead
Grubhead
