Question about LG WM2301H Washer
LG WM2301H ball bearings issues - LG WM2301H Washer
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
See my answer on your prior post!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Posted on Dec 15, 2015
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: How to Replace Bearing Ball on a LG Front Load
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
Posted on Jul 04, 2010
My LG WM2301h won't drain. I have tried cleaning the hose but either did not clean it or that is not the problem?
I can almost certainly tell you that Your Pump is gone! There is no way to check them because the symptom you describe is the check! The pumps go for $35 to $135. So shop around and get ready to take your entire machine apart. Good luck
Dec 01, 2015 | LG WM2301H Washer
How do I find serial number in LG washer WT 1101CW
OK, On my prior post for your LG I answered this question (One of four) you posted!
Jun 28, 2014 | LG WM2301H Washer
Lg wm2301h turn on by itself
This is something that you NEED to call LG on and have them fix it! Because I can tell you it is a fault in your computer board. Cost $200-700 dollars!!!! Yeah right! If you need to replace the Brain of any unit you might as well get another unit. It was faulty from day One!!!!
Apr 06, 2014 | LG WM2301H Washer
Washer won't turn on
Lets see here I read that you have three separate problems. Uhhhh
1) Ball Bearings
2) Hard reset
3) Going on
4) Serial number
Now I'm going to give you a method to start with, complete, then move to next issue.
FIRST!!!!! Get you owners manual and turn to the LG page for Customer Support. Now, if you sent your Registration card then They will have the serial Number. Other places back of machine, Tub opening inside/behind door.Now "If" you're having ALL these problems there is a chance here that you need a NEWER/NEW one under warranty to be replacing the machine you have.
NEXT....
Turning the Machine Off/On by pulling the Plug (ALL THE TIME!!!) Is a symptom of the Computer Board (Brains) has a fault (broken) and needs to be replaced. These are VERY expensive $300-$700 depending on model, yr bought, And if this is the issue and you have no warranty left. Buy another LG ERRRRR! Stop! Stop!
Whatever you do DO NOT BUY ANOTHER LG MACHINE!!!!
When Mine went after 8.5 yrs I had the same problem as you. I bought a "Used" Whirlpool (Commercial Grade) for $150. I have had THAT machine for 16 yrs! No problems AT All. So look at Top Loaders Whirlpool (Duh!), Maytag, or Samsung.
To "Reset" your machine you disconnect from power for 30 minutes then plug in/
Ball bearing are Not on these machines, they use a thing called a Stader. Which is a MAJOR replacement issue. Finally...Who told you that you had these problems?
Hope it works for you, please let us Know! We are here to assist you!
Apr 04, 2014 | LG WM2301H Washer
Lg wm2301h keeps saying oe
problem with water not draining..kindly check drain motor..
Feb 05, 2014 | LG WM2301H Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Jul 04, 2010 | LG WM-0532HW Front Load Washer
LG WM2301H Washer Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
