Question about Garden
I have a Craftsman 22" mower that is self propelled nd key start with battery and charger. Can I use the mower without the battery charged? I'm having trouble getting it running.
Model 917.376240
#1 Taper
  • 1040 Answers
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
Posted on May 30, 2009
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Can't remember how to charge battery in craftsman 675 lawn mower
first hook up positive side of charger then negative side of charger make sure you do this in open air so battery gas can excape while charging
Sep 26, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Can"t charge battery
Could have 1 or more problems. Bad battery, bad charger, bad wiring/connection, blown fuse, or some had a protection diode in the + line in which could open. Would check fuse first.
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
How to change battery in my 917376536 craftsman mower
if it is a self propelled mower it is in the center of the handle assembly a black box
Jun 29, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
What kind of battery does it take
Mowers don't typically take batteries. Possibly riding mowers might, but not push/self propelled mowers. They run off a spark plug and gas and that's it.
Jun 13, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
My lawn mower will not start using the key not sure what is going on I checked all the conections, and made sure that the battery is charged please help.
Hi. If the battery is fully charged you probably have either a loose battery cable, a corroded battery cable or a corroded key switch. Disconnect the battery and scrub the battery connections and cable connections with emery cloth til they shine. Then spray some electronic contact cleaner into the key hole and on the key and insert it several times to clean it up. J.
Aug 10, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
