Question about Honda Electrical Supplies
How to remove a honda gx 340 motor from a wacker neuson gp6600 generator
I need to know how to remove a honda gx 340 motor from a wacker neuson gp6600 generator?
  • 3 Answers
SOURCE: Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Posted on Dec 24, 2008
gisvc
  • 40 Answers
SOURCE: 1985 honda shadow vt500c pulse generator
hi,
locate the crankase cover to the left of the engine towards the lower end of the motor. if the bike has a center stand place it upon it t\and undo the crank cover once removed you will visually see the pulse generator it is like a large type style magnet. good luck
live free ride hard..
Posted on Mar 30, 2009
  • 22 Answers
SOURCE: pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
kel1guy2002
  • 3740 Answers
SOURCE: Looking for manual for honda pressure washer,its a
Go to this page:
http://www.jackssmallengines.com/help.cfm
You must have your exact engine model number listed on the side of the engine crankcase near the lower mount and oil plug.
Thanks for choosing FiXya.
Kelly
Posted on Jun 24, 2010
  • 142 Answers
SOURCE: Hi, i have two honda
  1. If you check on generators output and you have voltage there, your circuit breakers may have dropped.
  2. If there is no voltage there, you may have:
  • Bad slip rings, brushes, wires to field winding;
  • Bad field supply rectifier;
  • If the field circuit is OK, the magnetic field may need to be recharged
In order to build the magnetic field up again you can connect for a short time (1 - 3 seconds) by a working motor, a 12 V battery to the field terminals, + and - respected. A series diode 10 - 25A to battery can stop the built up field voltage to overcharge the battery.
Posted on Aug 03, 2010
Hi I have a Dunlite UH5 generator coupled to a Honda GX 340 Generator is noisy. Is there a parts list or workshop manual I can get to explain how to identify and repair the generator ?
Hi, You can get parts from "Generator Guru" for your Dunlite generator and your Honda, as it sounds like the anti vibration engine mounts are shot.
Sorry, but I can't help you with the manuals.
Kind regards
David
Jan 16, 2018 | Honda Electrical Supplies
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Can i run my honda gx 340 without the balance gear
if it has one then ---NO
balance shafts are there to extend the life of the motor by removing damaging vibrations
Nov 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Have a new Wacker neuson gp2500 generator that
Be sure the oil is at the right level and the sensor is connected properly.
Oct 08, 2014 | Electrical Supplies
Where can i get a part for a ps200
http://www.tmsequip.com/part/wacker-neuson-part/wacker-neuson-part-0152391-impeller-ps2-400-500-psa2-500/
Sep 26, 2014 | Wacker 2" PS2400 Submersible Pump...
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Will a honda engine gx 340 11 hp engine fit
no it will not fit unless some modifications are made
Sep 13, 2009 | Garden
Electrical Supplies Logo
21 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
