Question about Sony Cyber-Shot DSC-S90 Digital Camera
Shuter is not opening,format error c13-01 - Sony Cyber-Shot DSC-S90 Digital Camera
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
ALL COPIES BLANK. NOT LOW ON TONER. ALREADY REMOVED AND SHOOK. D320
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Jun 23, 2011 | Canon imageCLASS D320 Digital Copier
I DROPPED THE CAMERA AND THE SHUTER WILL NOT OPEN
You might exercise the shutter to see if you get lucky? Take more pictures? Service is too expensive, easier to buy another new camera.
Dec 22, 2010 | Samsung L700 Digital Camera
The shuter stays open for to long
There is a reset pin inside the Battery Compartment...give that a try.
Mar 19, 2010 | Nikon D200 Body Only Digital Camera
Nikon d60 shutter release error
press shuter release button again
Jun 22, 2009 | Nikon D40x Digital Camera
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
Jun 02, 2009 | Canon iR 2020i Laser Printer
Camer of n79 did not sart when shuter open
remove yor camera flaf and joint the copper pin and chek this open so change this back cover
Apr 23, 2009 | Nokia N79 Cellular Phone
Shutter release and film and advance not working on Olympus OM-N1
for shuter ,the spring ,or mirror lock wornout,rebts in shuter may wornout,for film advance lever cheek for rewind buton on botm
Apr 15, 2009 | Photography
Sony ericsson 700i camera
If you open the shuter quickly this tends to happen.
Mine has to be on the main screen.
Jan 19, 2008 | Sony Ericsson W700i Cellular Phone
Sony Cyber-Shot DSC-S90 Digital Camera Logo
13 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
