Question about Intertel Inter-Tel Axxess 550.7300 also known as 550.8560 Charcoal Phone with LCD Display
I have the administrative phone and the voicemail has locked us out. It won't let anyone check the messages. Is there a way to change it so we can get in?
The password has always been the same and now it won't let us in.
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
I have downloaded the manual for the Avaya phone system that we have (Avaya Partner 18D). But I cannot find where it describes how to change the systems' administrator message for all calls. We are...
You dont need to the phones user guide, you need the Voicemails administrator guide.
You will need to know what voicemail you have, as there are a bunch that could be on your system.
Feb 21, 2011 | Avaya Corded Phone avaparp18d
I have a Norstar T7316E phone system. I need to
Depending on the type of voicemail you have It can be accomplished by calling in to the office and when the main greeting starts playing press **, the administrator mailbox number, the password and the pound key (the administrator password must be changed from 0000). Once in the mailbox press either 9 or 99 at this point you can re record the main greeting.
Feb 24, 2010 | NorStar T7316E Corded Phone
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
Need to set password
To keep your voicemail messages secure most vendors keep this is an administrator function or at least a technician level change, you will need to contact your system admin or your Phone vendor to reset your pass-code.
Mar 13, 2009 | Mitel 5220 IP Phone
T7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
Jan 21, 2009 | Nortel Business Series Terminal T7208 -...
Would like to change voicemail message in phone
-Dial into voicemail
-Enter password to access system
-Press button for Greetings or Administrative Options menu
-Choose type of greeting
-Press button to change it and record new greeting
-Listen to new greeting and press button to confirm
-Exit system
May 02, 2008 | Cell Phones
Partner 18D System - Voicemail
Your telephone can be used on different Avaya phone systems and you can have different voice mail systems. They all program differently.
Someone should have administrative rights to the voice mail. They can delete voice mail boxes and create new ones or maybe just change the password. If you do not have a phone system administrator, you would need to determine what voice mail system and what phone system you have. All the manuals are available at www.avaya.com
Most likely you have a Partner ACS system but there are different versions. You could also use these phones on a Magix system and other Partner systems.
Nov 12, 2007 | Lucent PARTNER18 Corded Phone
Intertel Inter-Tel Axxess 550.7300 also known as 550.8560 Charcoal Phone with LCD Display Logo
23 people viewed this question
Top Intertel Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Intertel Lands Phone Expert? Answer questions, earn points and help others
