Question about Cuisinart DCC-1200 Coffee Maker
Switch will not turn on machine - Cuisinart DCC-1200 Coffee Maker
How to install new switch?
Remove the back cover of the machine by removing the 2 screws on the back.. Pull the back cover off, and you would have access to the power switch on the back of the machine.
Purchase a switch click here.
SWITCH NE03 028
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
May 27, 2015 | Saeco Incanto Classic Espresso Machine
Why it doesn't spin
almost all washing machines have a special switch to turn off or don't let spin when door is open. If machine 'thinks' that door is open, won't spin. "" Danger, Will Roberson...Danger..."" If you don't know what U are doing, please get help. An open switch looks like door is open.The switch is INSIDE the body of washing machine, ON the door is a plastic piece that pushes the switch lever in. You have to place 'jumpers' across the contacts on switch,shorting switch and turning machine to spins cycle.
Feb 16, 2013 | Washing Machines
I have a rancillio. The steamer works really well for about 15 seconds and then peters out???
Descale the boiler with citric acid.
  1. Turn off the machine and let it get cool
  2. Dissolve about a tablespoon of citric acid in the water reservoir.
  3. Turn on the machine and then pump about a cup of solution out of the boiler vent using the hot water switch.
  4. Turn off the switch. Close the vent
  5. Let the boiler heat up for about 5 minutes.
  6. Shut off the machine. Let the acid work for about 30 minutes.
  7. Check the level in the reservoir.
  8. Turn on the machine and then pump about a cup of solution out of the grouphead using the brew switch.
  9. Turn off the brew switch.
  10. Repeat steps 5,6, 7, 8, and 9 until the water runs clear.
  11. Wash out the reservoir.
  12. Turn the machine on. Pump a full reservoir water out the grouphead using the brew switch.
  13. Refill the reservoir.
  14. Have some coffee
Dec 02, 2012 | Rancilio Silvia Espresso Machine
Pump won't turn off on my Rancilio Silvia. I left machine on for about 1 1/2 hours, then brewed the expresso and when I tried to turn off the pump switch, it didn't go off. Now every time I turn on the...
The pump switch is either burned out, shorted out, or there is a CPU problem. You will need somebody local to do basic electrical troubleshooting on this machine.
Jan 23, 2011 | Rancilio Silvia Espresso Machine
My machine emptys the water but it does not turn
If the machine gets water but does not turn, then check lid switch, motor, and control board.
If no water is getting inside the machine, check inlet valve, water level switch and control board.
Jul 31, 2009 | Kenmore Washing Machines
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Power switch will not turn on machine.
There is a power switch at the right rear of the machine. Is this on?
Jul 09, 2008 | Solis Palazzo Espresso Machine
Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Aug 23, 2007 | Toshiba e-Studio 350 Copier
Cuisinart DCC-1200 Coffee Maker Logo
20 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
