Question about Cameras
Sanyo mt 4200 - Cameras
Cam specs on a 1967 Pontiac 400, 335 hp
Firebird App. Pontiac Part # Duration @ .050 Degrees Int/Exh Adv Duration Degrees Int/Exh Lobe Center Degrees Int/Exh Lobe Separation Angle Overlap Cam Lift Int/Exh Gross Lift Int/Exh
(1.5:1 Ratio Rocker) Gross Lift Int/Exh
(1.65:1 Ratio Rocker) 1977 TA6.6 549431 274/289 62 .249/.270 .374/.406 .411/.446 1978 TA6.6 10003402 273/289 54 .270/.271 .406/.407 .446/.448 1979 TA6.6 10003402 274/298 55 .249/.270 .374/.406 .411/.446 1967 400, 1968 350, 1973-76 400 w/ AT 9779066(E) OEM 200/210 273/282 106/116 111.25 55 .272/.271 .408/.407 .449/.448 1967-68 400HO w/ MT 9779067(P) OEM 200/213 273/289 113.5 54 .272/.271 .408/.407 .449/.448 1968 400 HO MT & RA-I AT, 1969 350 HO MT, 1969 400 MT, 1970
RA-III MT/AT, 1971-72 455 HO MT 9779068(S)
OEM 212/225 288/302 113/118 116 63 .272/.271 .408/.407 .449/.448 1967 RA MT/AT, 1968 RA-I MT,
(Some 1969 GTO RA-III MT) 9785744 (H)
OEM 224/236 301/313 112/119 115 76 .272/.271 .408/.407 .449/.448 1968-70 RA-II & RA-IV MT/AT 9794041
(T) OEM 230/240 308/320 112/115 114 87 .313/.313 .470/.470 .516/.516 (Stock in RAIV)
Sep 20, 2017 | Pontiac Cars & Trucks
MY TV SHOWS NO SIGNAL ALSO NO SOUND ON MT VIZIO 39 TV
Do you get any sound from a dvd player hooked up with av cables yellow,red,white?
Aug 29, 2014 | Sanyo Vizon LCD-15A2 Television
I wana make my I pod touch 4g as my Sanyo tv remote but I don't know how to find it
Look in the App Store. For example, there's Control It All-Remote by MiCommand.
https://itunes.apple.com/app/control-it-all-remote/id431778312?mt=8
there's a few others in the apple store. Just browse the store and search for "remote" on itunes.
May 28, 2013 | Televison & Video
Remote code for the Soyo Model # MT-SYTPT4218AB What's your problem?
These are setup codes for Sanyo: 0049 0097 0110 0004 0268 0012 0108 0180
Oct 25, 2012 | Soyo SYTPT4218AB LCD TV
I would like to install a second HD on my HP Pabilion a1540n desktop. What are the specs so I can buy it.
HP Pavilion Media Center a1540n Desktop PC Product Specifications
Hardware Base processor Athlon 64 X2 (W) 4200+ 2.0 GHz
  • 2000 MT/s (mega transfers/second)
  • Socket AM2
Chipset GeForce 6150 LE Motherboard
  • Manufacturer: Asus
  • Motherboard Name: A8M2N-LA
  • HP/Compaq motherboard name: NodusM-GL8E
Memory Component Attributes Memory Installed 2 GB Maximum allowed 4 GB* (4 x 1 GB)
*Actual available memory may be less Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM Hard drive
  • 250 GB SATA
  • 7200 rpm
16X DVD(+/-)R/RW (+/-)R DL LightScribe drive
  • Must use Double-Layer media discs in order to take advantage of the DL technology
  • Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
Sep 04, 2011 | HP Pavilion a1540n PC Desktop
What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
Aug 10, 2010 | 1992 Ford F250
Need to know the steps on how to solve this equation: 1*4200*(45-q)=1.5*2400*(q-20) solve for q. Ans ~33, but need detailed workings. Thanks
Your answer is wrong anyway. (This should be clear since if you put in q=-33, one side will be positive and the other side negative.) This is just simple distributing and rearranging:
1*4200*(45-q) = 1.5*2400*(q-20)
1*4200*45 - 1*4200*q = 1.5*2400*q - 1.5*2400*20
189000 - 4200q = 3600q - 72000
189000+72000 = 3600q + 4200q
261000 = 7800q
q = 261000/7800
The answer is 33.4615 give or take a few places.
Mar 08, 2010 | SoftMath Algebrator - Algebra Homework...
LOST PRINTER SCX 4200 SAMSUN DRIVER CD
You can download the driver here: http://www.nodevice.com/driver/SCX-4200/get42791.html
Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Tape is stuck in sanyo vcr 4200
Take a phillips head screw driver,,take out the screws on the side and back of the vcr,, then pull the top off,, and reach in ther and pull the tape out,,, before you use the vhs player again ,,you might want to try a vhs headcleaner on it,,good luck,, thanks
Oct 05, 2008 | Sanyo Televison & Video
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
